I am building the following system and would like to stay with watercooling if possible. My current WC setup consists of:
- Laing DDC Pump
- Watercooled i7-3970x
- HUGE 360X360mm External Radiator (Mora 2 Pro)
I want to ditch the external radiator and use a standard 120 mm radiator if possible, as my case Lian-Li PCV-2120 is rather limited with internal mounting option without drastically affecting the cosmetics. I can mount a 240mm radiator on top but that would entail removing the top cover and the entire case looks unsightly:
My new component will be:
2x XEON E5 2699V4 CPU
1x GTX 1080Ti
I calculated the total TDP should not exceed 600w and I read some german all-copper 120mm radiator can dissipate quiet a bit of heat...or am I living the pipe dream?
- Laing DDC Pump
1x GTX 1080Ti
