Should i use Auto tune?
343 Views 1 Reply 2 Participants Last post by  gian84
should i use the auto tune fucntion in CCC? i have a 4850x2.
PS: are 53Amps enough power?
1 - 2 of 2 Posts
Give it a try. You can always check the stability using a furmark, benching program, or by gaming anyway. I still suggest ocing manually though if you have the time.
53amps I think is more than enough for that card and your system...
1 - 2 of 2 Posts
