Should my core temp be 5+ degrees less than CPU temp?
367 Views 3 Replies 3 Participants Last post by  ny_driver
That seems like it's backwards, but thats what Speedfan tells me........and Everest confirms the CPU temp and that all the other temps are identical. Just no core temp on Everest. What do you think?
1 - 4 of 4 Posts
Just go by the core temps.
Core temp should be more. I get like 60C core temps and 40C CPU temp.
I cut a 6 inch hole in the MB side of my case and mounted a 6 inch independently powered intake fan there , which blows directly on the back mounting plate of the CPU. You think that could cool it that much?
Well..I finally got Coretemp to work and it verifies the core temp reported by Speedfan.
............all temperatures reported by Speedfan have been verified by another program.
1 - 4 of 4 Posts
