Originally Posted by Veto1024 Yah but im trying to compare huge folders checking to see where this file transfer failed and all i got to work off of is comparing size and its so slow doing it that way! |
Originally Posted by Veto1024 Its not having the computer count up the space thats hard. its not because the files are mainly big ones. The problem is i had like, 3 main folders with about 30 sub folders each and i just needed to figure out where the transfer went wrong by comparing sizes. So once i figure out which main folder is off, i go into the sub folders. But then its like, comparing 30 folders on each drive to find out where it went wrong. I do kinda like programs do with their search routine though. I took half of the 30 folders and compared size with the corrosponding half on the other drive. I could then eliminate 50% of the job everytime i did that. Doing it 30 times would take sooooo long so this helps me ![]() |
