1 - 8 of 8 Posts
If you are getting the points for them....then yep...enjoy it. If not then it's probably a site error. It is also possible for the program to error out and keep resending units as soon as they start...which gives you a count boost and sometimes/sometimes not a point boost. I once got credit for 18 wu's in a day and that was impossible.
I once turned in 275 WUs on one computer one evening according to Stanford's website. Sometimes their servers get a bit goofy and don't handle submitted work quite right. They get the points correct, though, so it's not a big deal in the long run.
In my case, it was a server error. The computer in question was at stock everything across the board and was rock solid.
1 - 8 of 8 Posts
