Would you wanna see the comparision?
  • Yes
    Votes: 1 100.0%
  • No
    Votes: 0 0.0%
1 - 1 of 1 Posts
So im thinking of doing some tests. I currently have noctua nf-f12's and am probably gonn test them against Cougar 120mm PWM fans. I am also thinking of including a cougar with and with out shroud test. One if the biggest downfalls of the cougars (imo) is that it not a square frame and obviously a square from provides better performance on a radiator. So I think it would be interesting to see how the a non square frame fan with and with out a shroud would peform. What are you guys's thoughts? Would you wanna see this comparision? noctua nf-f12 VS cougar 120mm pwm VS cougar 120mm pwm with a shroud
1 - 1 of 1 Posts
