^^ No I don't believe that's what the OP is looking for!
That's your standard run of the mill "Right angled" SATA (Which is actually angled 90 (right angle) out the bottom/top.
He wants one that angles out the SIDE (left/rght)
That correct???
You tried DigiKey or Mouser?
*goes to look*
Cheers
Originally Posted by Fantomau
Yeah I was just wondering if they made 1 like that instead of the run of the mill straight, left, right angled.
They do.... The types of SATA are straight, right-angle, 90-degree, and 180-degress. Can't have the left-angle ones cause they would hit the power plug.
I've seen them before but are hard-to-find. I think CD used them once?
Overclock.net
