1 - 2 of 2 Posts
I'm rebuilding my home server and it has a side panel 120mm fan for direct airflow to the RAID controller. So while it is necessary I despise running a cable to the fan that needs to be unplugged and plugged back in when the side panel is removed.
Does anyone know of a (spring loaded?) contact connector I can use to ditch the cable? The fan is a 3-pin
Iconoclast
I don't know of any such connectors, but a simple extension cable should remove the need to unplug the fan.
1 - 2 of 2 Posts
