There are a few different ways to add a window, depending on what you want it to look like--there's the gasket style with a special vinyl "H" channel that holds a window to the panel--there's the kind you attach from the inside with double-sided tape or silicon which require a pretty nice cut with a carefully deburred edge--there's the type where you apply the window to the case with screws, rivets or adhesive. And other variants on that theme.
DO you know what you want it to look like?
