1 - 5 of 5 Posts
Senior Member
GPU doesn't matter that much.
CPUMark benefits from CPU speed.
Yes, the gpu score seems a bit on the low side to me for xfired 4850's.
You sure you don't have anything 'forced on' in the CCC like maybe AA or v-sync or anything like that?
Also, make sure that catalyst AI is not disabled, otherwise xfire won't work. Windowed mode will also disable xfire, just so you know.
1 - 5 of 5 Posts
