1 - 10 of 10 Posts
I know i've been pretty annoying on these forums (keep asking for help) buuut, only way i'll learn.<br><br>
This is going to be quite long, so bare with me.<br><br>
It all started when i wanted more FPS on games like Counter-Strike Source.<br>
At the time, i had a Nvidia GeForce FX 5500. It was ok, but when too many people got on the screen, it started to lag and i got low FPS. I then got my old graphics card from my old computer. I thought it was a ATI RADEON 9200 Pro.<br>
Because when i put it in for the first time, i right clicked on my desktop > properties > settings. And it said 'RADEON 9200 Pro Family'<br>
So i thought, cool, seems like an OK card. Now, when i installed the Drivers for it, it changed to a RADEON 9250. <img alt="" class="inlineimg" src="/images/smilies/frown.gif" style="border:0px solid;" title="Frown"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"> . I asked around on this forum about overclocking etc, and i found out i couuld use ATITool. About 10 minutes ago, i decided to remove all my Nvidia Stuff (drivers from my old graphics card) and my ATI Drivers, because i thought i could get the 'RADEON 9200 Pro' back..<br>
NOW, this is where i get annoyed. When i try to install any Catalyst driver for the ATI (i tried RADEON 9200, and RADEON 9250 in SAFE MODE, and normal) it gives me this error.<br><br><a href="http://img114.imageshack.us/my.php?image=errorcz2.jpg" target="_blank"><img alt="" src="http://img114.imageshack.us/img114/6533/errorcz2.th.jpg" style="border:0px solid;"></a><br><br><a href="http://img114.imageshack.us/img114/6533/errorcz2.jpg" target="_blank">http://img114.imageshack.us/img114/6533/errorcz2.jpg</a><br><br>
It happened to me before, but when i downloaded the driver from a different site, it worked. But now after i removed all my driver stuff with Driver Cleaner Pro, none of the installers work. I've tried removing my graphics card and putting it back in etc.<br><br>
I don't have my Windows Disc, so i can't reformat..<br><br>
Please, any help.<br><br><img alt="" class="inlineimg" src="/images/smilies/grouphug.gif" style="border:0px solid;" title="Grouphug">
So you removed everything (video card drivers) with DC already? Did you run DC in safe mode also (its easier to remove stuff that way)? Did you download the drivers from the ATI site? Try downloading them again.<br><br>
Edit: Just checked the ATI site and it says the new drivers (6.9) only support cards newer than the 9500s. You may have to hunt down older version on the web. Try Guru3D: <a href="http://downloads.guru3d.com/download.php?id=18" target="_blank">http://downloads.guru3d.com/download.php?id=18</a>
<div>Originally Posted by <strong>Melcar</strong></div>
<div style="font-style:italic;">So you removed everything (video card drivers) with DC already? Did you run DC in safe mode also (its easier to remove stuff that way)? Did you download the drivers from the ATI site? Try downloading them again.<br><br>
Edit: Just checked the ATI site and it says the new drivers (6.9) only support cards newer than the 9500s. You may have to hunt down older version on the web. Try Guru3D: <a href="http://downloads.guru3d.com/download.php?id=18" target="_blank">http://downloads.guru3d.com/download.php?id=18</a></div>
</td>
</tr></table></div>
I've tried all the ones from that site, but they all give me the same error <img alt="" class="inlineimg" src="/images/smilies/mad.gif" style="border:0px solid;" title="Mad">
You tried all of them? Did you try installing just the driver with the regular control panel (not the ones with the Catatylst Control Center)?
Discussion Starter #5
<div style="font-style:italic;">You tried all of them? Did you try installing just the driver with the regular control panel (not the ones with the Catatylst Control Center)?</div>
</td>
</tr></table></div>
No..Would you be able to tell me where to find that
I know that the Omega drivers use the regular control center. Try installing them and see how it goes. Make sure you download versions lower than 6.5 since versions 6.6 and up no longer support your card.
Discussion Starter #7
<div style="font-style:italic;">I know that the Omega drivers use the regular control center. Try installing them and see how it goes. Make sure you download versions lower than 6.5 since versions 6.6 and up no longer support your card.</div>
</td>
</tr></table></div>
I'm going to try the ones from this place<br><br><a href="http://www.omegadrivers.net/archive.php" target="_blank">http://www.omegadrivers.net/archive.php</a><br><br>
If none of these work..I'm stuck for ideas.<br><br>
Howcome when i first put the card in, it automatically detected what it was, and i could play CS Source straight away, and it was called 'RADEON 9200 Pro Family'<br><br>
Maybe you should take a look at this..I don't know if it helps or not..<br><br>
I went into Device Manager and..<br><a href="http://imageshack.us" target="_blank">[img=http://img242.imageshack.us/img242/737/fgdfgci6.jpg]</a><br><br><a href="http://img242.imageshack.us/img242/737/fgdfgci6.jpg" target="_blank">http://img242.imageshack.us/img242/737/fgdfgci6.jpg</a><br><br>
But then when i tried to install a driver, it went to the rubbish version (RADEON 92500)
Forgot the link<img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"> . Yeah, that's the place I was going to refer you to. Just make sure it's lower than the 6.5s. If I'm not mistaken, the 9250 is slightly better than the 9200PRO (could be wrong).
Reactions: Nikv
Discussion Starter #9
<div style="font-style:italic;">Forgot the link<img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment"> . Yeah, that's the place I was going to refer you to. Just make sure it's lower than the 6.5s. If I'm not mistaken, the 9250 is slightly better than the 9200PRO (could be wrong).</div>
</td>
</tr></table></div>
I downloaded and installed the Omega Driver, and it installed successfull, but then when i try and access 'ATI Tray Tools' it says 'Can not find ATI video board or no Catalyst drivers installed'
Discussion Starter #10
Wooooo!!!! I realised i didn't actually install the drivers, tehe.. <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br>
I installed themand everything is good again.. And for some reason look what shows up <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br><br><a href="http://imageshack.us" target="_blank">[img=http://img116.imageshack.us/img116/2857/yeskk7.jpg]</a><br><br><a href="http://img116.imageshack.us/img116/2857/yeskk7.jpg" target="_blank">http://img116.imageshack.us/img116/2857/yeskk7.jpg</a><br><br><br>
Now for some reason i have a '9200 Pro' card <img alt="" class="inlineimg" src="/images/smilies/tongue.gif" style="border:0px solid;" title="Stick out tounge caps"><br><br>
I'm not complaining or anything, i would just like to know why this happens.<br><br>
Thanks TONES of your help! +rep
1 - 10 of 10 Posts
