1 - 9 of 9 Posts
I need to know were they keep the error report folder ( if any ) this isn't SE just streight up windows 98 i'm fixing my freinds boss's computer and well its a heep, so were is the error folder so i can tell whats going wrong becaseu i honestly see nothing wrong, been running for a few hours now and runs fine. They said they got a black screen and couldn't even hard power it down ( they really said hold the big button on the front of it ).
OVERCLOCK IT OR DIE
bootlog.txt ?<br />
<br />
I can't remember an actual file being created in 98 for errors. I know of detlog, bootlog, and setuplog. They should all be in the root directory.
how about the "upgrade to XP immediately log"?
OVERCLOCK IT OR DIE
<tr>
<div>
Originally Posted by <strong>kingwilliam</strong>
</div>
<div style="font-style:italic">how about the "upgrade to XP immediately log"?</div>
</td>
</tr>
</table>
</div>Fix the problem with XP and a conroe eh?
Discussion Starter #5
jesus they have a celeron 700 mhz, i don't think they want a csd and they have windows 98 becaeu they are old and odn't know any better, i was just asking help not whati should do with the computer thanks modki for first comment but not youer second
OVERCLOCK IT OR DIE
Actually my second comment was a comment on the third post, the first comment by kingwilliam and his comment about getting xp and being generally... well not very helpful.<br><br>
Those are the three (four?) I can remember from my days of messing with 98, a lot of stuff I know now only involves XP and it's superb system of tracking all the wonderful errors that occur with it.<br><br>
But to let you know in all honesty a Celeron 700Mhz will run XP just fine even with some of the visual styles turned on. Yes thank you for pointing out that that's besides the point.
Administrator
<b><span style="text-decoration:underline;">Guys he wants help not upgrade advice.</span></b><br><br>
The File you are looking for should be the Bootlog.txt file. Have a file search performed in the Windows folder and you should find it mate.
OVERCLOCK IT OR DIE
<div>Originally Posted by <strong>ENTERPRISE1701</strong></div>
<div style="font-style:italic;"><b><span style="text-decoration:underline;">Guys he wants help not upgrade advice.</span></b><br><br>
The File you are looking for should be the Bootlog.txt file. Have a file search performed in the Windows folder and you should find it mate.</div>
</td>
</tr></table></div>
<img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"> That's what I said. <img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><img alt="" class="inlineimg" src="/images/smilies/confused.gif" style="border:0px solid;" title="Confused"><br>
Well I said the root (some people named their's c:\\Win c:\\Win98 or c:\\Windoze or etc..)<br><br>
Then kingwilly goes off on the XP tangent. Big said it's only got a 700MHz celly and I pointed out a 700Mhz celly <b>would</b> run xp just fine but that's beside the point now.<br><br>
BOOTLOG.txt will only give you errors with startup.
and how do you know it wasn't dust<br />
i have seen comps that wouldn't post and the they take the side pannel off and it be fine!!!
1 - 9 of 9 Posts
