Give fans lower voltage, like if they're 12V fans, give 7V(a bit complicated) or 5V(easy).
Remove fans you don't need.
Change fans for proper 120mm ones and lower their voltages.
Put up silencing dust-filters and rubber bolts for the fans to reduce the vibration.
