1 - 1 of 1 Posts
Q: Using modified Haf 932 with one 360 rad in top and one 240 in bottom, using gentle [email protected] will it handle 400-500w of heat?
My understanding is that waterpump needs under 60c?
I own 4x pump that I think are DDC 1 and also own a D5 pump, Ive heard good things about D5 so mostlikely going to use that in this as single loop if possible.
So I'm building my first watercooling and I want it to be quiet so I can not just game but other stuff aswell.
I ended up with a used Aquacomputer airplex XT 360 http://www.aquatuning.de/product_info.php/info/p3363_Aquacomputer-airplex-XT-360.html
And a used EK Water Blocks EK-CoolStream RAD XT 240
http://www.aquatuning.de/product_info.php/info/p8084_EK-Water-Blocks-EK-CoolStream-RAD-XT-240.html
So at most I will have one 360 in top and with removing harddrive cage and dremeling a 120 hole I can install a 240 EK rad in bottom.
My hope is to run all fans in case 500rpm, for radiators most likely I use Gentle Typhoon ~500rpm as Slipstream are not good for horizontal rads.
It will either run 100w cpu + 2x 7970 so 500w or 100w cpu + 2x 6950 so ~400w
1 - 1 of 1 Posts
