Had spent a lot of time looking for drive changes that offered good cooling and accessibility. In the end the only thing I could find that met my need was the ICY DOCK Black Vortex. It has the following features that I like but a few that I do not:
Pros:
-Front mounted fan with thus front mounted dust filter so it is easy to clean and easy to replace the fan
-Drives remove from the front so they are easy to remove in any case
-No backplane to block airflow and thus keeps the drives cooler, the minor inconvenience of needing to open a side panel to unplug 2 wires is worth it
Cons:
- Drives do not have any sort of anti vibration damping.
Photo: https://images.tweaktown.com/conten...k_black_vortex_3_5_drive_cage_review_full.jpg
Solution: add some sort of vibration damper to the bottom of the drive or to the cage ledges.
The drives slide onto plastic ledges along the side of the cage and lock into place via an attachment mounted to the front of the drive. There is a few mm of z access space which could allow for some vibration damping to be placed under the hard drive between it and the ledge.
I was thinking of using something like this for the material options seem to be between 45A or 60A but not sure what that means: https://www.homedepot.com/p/Rubber-...bber-Sheet-Black-20-109-0062-36-072/303366679
Ideally I would like to find a smaller sheet for less money.
Any comments on this idea or other suggestions as to solutions? Also yes I am obviously replacing the fan that comes with it.
Suggestions on how to attach the rubber to the ledges or the drive?
Pros:
Cons:
