Silent Hard Drives??
484 Views 13 Replies 6 Participants Last post by  ThaLoveDocta
Looking for the best silent hard drive. Should i go with Seagate or Western Digital?
1 - 14 of 14 Posts
My seagates run almost perfectly silent
compared to my old IDE WD 160 they're much quieter.
they are SATAII 320 GB 7200.10 perpendicular recording ones.
so seagate over WD? BTW,Hows your build coming along?
Samsung Spinpoint HDD are probably the quieter than WD or Seagate. In most cases, you'll lose some performance/capacity for silence. You may want to even go with a quiet 5000RPM drive. You other other is get an cooling/silencing internal enclosure for your drive.
i've been running into some stability issues and some heat issues but they will be resolved by weeks end i have the Swiftech NB cooler on it's way to deal with that (speedfan reported 127 degrees on the AUX!! i think its' an error though. but it's still too hot to touch.) I think the NB caused the stability problems. and a BIOS update is needed. Also i have more CAT5e arriving on friday, to fix that up, and finally some real AS5 rather than the stock stuff, so i can put it on the NB and the CPU. Otherwise it's great! the RAID array setup fine (eventually) and i can clock to 2.9 fairly easily under 1.4V.
you don't have to know slade very well to know that he will not be buying a 5000 RPM drive, or anything that will compromise performance. and in my opinion the seagates are quieter than the WD's (my gf has a WD too) and they are also thankfully the top two HDD's on the market
(WD 16MB and Seagate 7200.10)
You should try to find a solid state drive
My WD is quieter than my samsung spinpoint
yes i would say you are correct
my samsungs are quick and nice a quiet.... the only thing i can hear from them is them viabrating my alloy case - but thats only my IDE that does that
my SATA is silent... and very fast
Does 2 7200 rpm Drive on Raid 0 better or equal to a Raptor?
many say it's indistiguishable. i've never used a raptor so i'm not sure... but these drives are stupid fast the way i have em now.
I love my raptors but they're loud and not enough storage capacity. If its equal in performnace then im going to get 4 in raid 0
4 what?
4 x 250gb Seagate Hard drive going to be in raid
sounds good to me man! it'll run really fast and you'll have about 950 useable space!
1 - 14 of 14 Posts
