1 - 4 of 4 Posts
I'm building a PC for a friend and would like some recommendations for a silent, efficient PSU for an X99 / 5930k PC which will only really be used for RAW photo editing and watching movies, no gaming whatsoever. I'm presuming it won't need to be that powerful maybe around 650W should suffice. It won't be overclocked either so just running at stock with a couple SSD's and a couple hard drives.
Cheers.
Senior OCN Member
Which video card is going to be in the machine?
He's currently got a Radeon HD5450
Senior OCN Member
All you need then is a good 450 watt PSU.
But since everything under 500 watts is way overpriced i would just get a 550 watt.
The EVGA SuperNova G2 and the Corsair RMx are both good options in that wattage range.
1 - 4 of 4 Posts
