1 - 20 of 51 Posts
I'm looking to switch to water cooling for my sig rig. I've read up a bit on watercooling but I'm still very much a newbie. My current air cooling setup is fine at keeping temps down but its quite loud and on hot days it heats up my room, big time.
I was hoping for some suggestions on what parts to get for a complete water cooling setup. The loop is to include the CPU + 1 GPU. I don't need a waterblock for the GTX 260 because I will be upgrading to a Fermi card whenever they are released and watercooling that instead. The loop should also be able to handle a 2nd graphics card if I ever go SLI.
The most important thing though is, I would like the cooling setup to be near silent. I imagine the loudest parts would be the pump and radiator fans. My budget is between $300-$500 but it can be increased if neccesery. My overclocks arn't huge so I dont need the very best, most uber parts, just good value for money and quiet parts.
Thanks
EDIT: Added Loop Components
CPU Water Block: EK-Supreme LT Acetal+Nickel $62
Radiator: XSPC RX360 $115
Pump: EK-DCP 2.2 $59
Reservoir: EK-Bay Spin Reservoir Acetal $60
Fans: Scythe Gentle Typhoon 120mm Fan 1150rpm x3 $29 x3 = $87
Tubing: Tygon R-3603 Laboratory Tubing (Clear 3/8 5/8 1/8) x3 (3m total) $12.95 x3 = $38.85
Coolant: Distilled Water + PrimoChill Liquid Utopia-3ml, Clear + Red Food Coloring $0 + $5.95 + $0 = $5.95
Compression Fittings: Bitspower G1/4 Black Sparkle Compression Fitting CC3 x10 $7.50 x10 = $75
T Block + Stop Cap: T Block + Stop Fitting $3.95 + $3.25 = $7.20
GPU Water Block: Waiting for Nvidia to release Fermi then getting one of those + a full cover water block to go with it.
AUS $510.00 + shipping (without GPU blocks)
Mount the rad outside your window. Put a lil anti freeze in it and bingo...Silent. You will have to engineer running tubing to it. Crack the window and cut a sheet of plywood with holes for tubing. Put a little insulation to fill any air gaps. I use quick connectors on my tubing.
Super Moderator
Gotcha. Here's what I can suggest for those requirements;
Heatkiller 3.0 LT
XSPC RX360
3x Zalman ZM-F3s, using the included 7v wires
Any rebrand of the Jingway 600 (Danger Den CPX-1 and EK DCP 2.2 as examples), or even the Eheim 1046 (can be bought as the Aquastream XT if you want to control it with software); both of these are VERY quiet and will have enough power for a loop like you're after; however for the Eheim you do need a G1/4" adapter set, which Sidewinder carries
Masterkleer 7/16" ID / 5/8" OD clear tubing
Bitspower barbs/compression fittings (must match ID and OD for compression fittings)
For the video card blocks... well, I'll leave it to you if you want to try a full-coverage block like from EK or Watercool (all-in-one solution, but only works for a specific card or range of cards), or a universal like one from Swiftech (works with all GPUs but does not cover the MOSFETs or RAM chips).
Thanks for all the replys. Heres what I've got:
Radiator: EK-CoolStream RAD XT (360)
Pump: EK-DCP 2.2 (12V DC Pump)
Reservoir: EK-Reservoir Combo DCP 2.2
Fans: Zalman ZM-F3 120mm Silent LED Fan Red
Tubing: Swiftech Tubing 7/16" x 5/8" x 10ft
Coolant: Swiftech HydrX Coolant
Barbs/Fittings: ???
There was a cheaper Swiftech rad but I thought I may aswell go all EK
The thing that has me most confused at this point are fittings/barbs. Dont know how many or which types to get. Couldnt find any fittings with the same ID/OD as the tubing.
Also, Im not sure if the pump is enough for a loop with a CPU and 2 GPU blocks on it. Can anyone confirm its fine?
Im still very much open to more suggestions.
Thanks
Super Moderator
Use distilled water with a biocide (PT Nuke or a silver coil) instead. The coloring in fluid like that tends to separate and clog the parts over time.
Barbs/Fittings: ???
Just get whatever you like and get tubing that matches the dimensions of the barbs/fittings. Get 2 barbs/fittings for each part of the loop, and 2 extra for if you get another graphics card.
They're nearly on par with each other, so that's always good.
Yes, it's fine, and it'll be very quiet.
Get the high flow bitspowers.
You don't need to clamp it, since the fit will be tight.
You need 6(or 7) barbs: 2 for CPU block, 2 for res (or 3 if you plan to make a T-line/drain), 2 for rad. Pick up 2 more for each GPU block you plan to add.
The rad and I think res should come with barbs, but it's better to use the high flow barbs since it forms a tighter fit with the tubing.
I would opt for the Swiftech rad if it's cheaper, since performance is roughly the same. Plus as you mentioned you aren't going for heavy overclocks.
Again, like the above poster, use distilled water and a biocide instead of a mixture.
Thanks for the help, +rep to you both.
Think I'll go with the cheaper Swiftech rad and save a few dollars.
Distilled water is easy enough to get but I dont know where to get PT Nuke or a KillCoil here in Aus. Are there any other biocides that you know of that i can search for or will something similar from a pool/pond shop do?
Super Moderator
Just ask any shop of that sort that can ship to you if they carry copper sulfate-based biocides. I'm sure you'll find something. Usage of such is one drop per litre if you do find any.
Super Moderator
OK, last 2 questions.
If I get a bunch of these barbs: Swiftech 3/8 Inch Chrome Plated Barbs,
will this tubing: Feser Tube - UV Red, 3/8" work fine?
PC Case Gear only has these and the Tygon's are too expensive and the Swiftechs wouldnt fit properly over the 3/8" barbs right?
And finally, will I need any clamps or ties with these barbs + tubing? I'm thinking yes.
Yes to both questions.
Discussion Starter · #16 ·
Final List:
Radiator: Swiftech MCR320-QP
Pump: EK-DCP 2.2
Fans: Zalman ZM-F3 120mm Silent LED Fan Red x3
Tubing: DD Tube - UV Red, 3/8", 5/8", 1/8" x4 (4m total)
Coolant: Distilled Water + Some copper sulfate-based biocide from a pool place
Compression Fittings: Bitspower G1/4 Black Sparkle Compression Fitting CC3 x7
Am I missing anything?
Do I need a backplate for the CPU water block?
Will I need an anti-corrosive additive since I'm mixing metals?
First off for the fans, if you want a super silent system, the Scythe Gentle Typhoons are much quieter than the Zalman's (I have both of them and they perform identical). These would be the ones you want:
http://www.jab-tech.com/Scythe-Gentl...m-pr-4501.html
That site you're using only has the slower ones though:
http://www.pccasegear.com/index.php?...oducts_id=8749
Also you only have to worry about mixing metals if there's any aluminum in the loop. Mixing copper, brass, silver, nickel is fine.
Discussion Starter · #18 ·
Interesting, thanks for letting me know.
Cheers for clarifying that for me.
Also, I edited my post above. Changed tubing and switched to compression fittings so I dont have to use 'ugly' clamps
Everything on your list looks good. You don't have any TIM (thermal interface material) on your list though, it's the gooey stuff you put in between the water block and processor if you didn't know
Some good ones are:
Arctic Cooling MX-3 4g
OCZ Freeze 3g
Shin-Etsu X23-7783D 1g
Notice though that the Shin-Etsu is pretty expensive especially since you only get 1 gram of it, but it's the top performer of the 3. Here's a review, just scroll down to the charts. I believe OCZ Freeze performs almost as good as MX-3, someone correct me if I'm wrong.
EDIT:
Also if you get the MX-3 or OCZ, you should have enough left over for the VGA block.
1 - 20 of 51 Posts
