Make sure you have some good heatsinks on the mosftets before you try overclocking an x6 to 4.00GHz on that mobo, and I hope you have a decent PSU as well.
As for the cooler, are you sure the silver arrow is going to fit inside your case? Those Coolermaster Elite cases are pretty small. It was tough fitting a modded AC Freezer 64 Pro in mine (my garage PC), much less a beastly heatsink like a silver arrow. The H50 will probably be the better choice in that case.
