Originally Posted by
shilka
SilverStone PSU´s by way are not all that good and most of them are mediocre so dont buy a SilverStone PSU there are much better options
Ouch, that's a harsh assessment for us! We don't think this is a fair blanket statement to describe SilverStone PSUs because we offer so many models that serve different purposes. Quite a few of our higher-end models can perform well against the competition when it comes to electrical performance (if that's the metric you use to gauge PSUs). However, we have shifted our focus for other models to excel in other areas, notably the physical reduction in size. Being a percentage or two lower in voltage regulation does not mean the PSU is no good or mediocre to use. Unless you are testing PSUs for a living, it make no difference to your PC's performance. However, a smaller PSU design can help improve build experience, compatibility, and cable management that users can appreciate immediately. Our design of flexible modular cable kit such as the PP05-E is also a result of this shift in focus.
So yeah, if you care only about the performance numbers from PSU review sites, then there are other options (some SilverStone models included). But other users may be better served with a PSU that gives them more than good enough performance but in a more compact, manageable sizes.
karbonkid
Surely there must be *some* cross-compatibility....
Anyone researched this before? If it comes to it, I could just re-wire the connectors...
shilka
The OEM that makes most of the units for SilverStone is Enhance Electronics and the only other big brand name that comes to mind that also uses Enhance Electronics is Cooler Master
If the cables work on anything they might and i say again might work on a Cooler Master PSU but i really doubt it
We were likely the first PSU brand to have unified our modular cable connectors back in 2009. So it doesn't matter if our OEM is Enhance, FSP, High Power, or Channell Well, etc... they will all have the same connector definition. Meaning you can continue using your PP05-E if you upgrade to new SilverStone PSUs later. There are some cross-compatibility because other brands may choose to use models that are made popular by us such as the SX500-LG or SX700-LPT. But to be sure, you should stay using SilverStone PSUs as we are committed to our modular connector definition for the foreseeable future!
