Here is a work log for my new build.
Build Log
Final Pics And Overclocking Results
Parts List
Full System Specs
Quick Laptop Repair
But this is what you will see in this thread:
RV02 fully sleeved case
Case Lighting Red / White
Custom cables for better wire management
2500k overclocking
raid 10 setup Raid 5 setup 4x 640gb drives
RAM clocking
3 Videocards
Blu-Ray
Many monitors
Sexy cable management
I am also going to need a new desk - or maybe some monitor wall mounts.
Parts Received Thus Far:
8gb DDR3-1600 Ripjaw (Did want faster but it was at a price i couldn't pass up)
Also in the pic 2x 640gb 3gb/sec 16mb cache WD drives. (i have 2 more at home that will be going in to create the raid 5.
ASRock P67 Fatal1ty Professional
LiteOn BluRay Player
LiteOn DvD/CD Burner/Drive
EVGA GT 430 1024mb (This is going to be my third card, this is just here to power 2 additional monitors. I got this card because of the thin profile, and it gets all the power it needs from the PCI-E slot, 1gb VRAM great for large monitors. Not to mention its not too shabby of a card either for sub $50
I also have received my Raven-02 Case but have already took it all apart and started sleeving and running cables.
Side window inside panel - I sound dampened it, left a gap for the bottom fan filters to sit so they wouldnt bend when i put it on.
Video Cards, CPU, and Heatsink have been ordered. Need to make some measurements tonight and order my last cables.
Doing measurements and testing cables to make sure i get everything cable managed perfect.
The back of my PC Power & Cooling Silencer 750w Powersupply - Not modular :[
Finished up the measurements, and i ordered extension cables to match. I have to stop in to frozencpu and pick up a couple sata cables, 2 fans, a fan grill, and some LEDs. Also forgot to mention i am LED swapping the Raven case light. Usually its
blue but i am changing it to red to match everything else.
Got 2 fans, one to replace the top exhaust fan, and im going to add the
kaze-jyu slim in the front behind the bay covers to cool the hard drives. Sleeving the fans, and changing the 3 pin connectors to red.
I added a
100 x 100 x 12mm fan to cool my hard drives, it is suspended behind a few 5.25 bays and angled slightly up to direct cool air over the drives. You can see in the pics below.
With cover kind of on
Backside without hard drives but all covers on
And here you can see the fan through the hard drive cage, another hard drive is going to be installed above it. But i am using that drive right now. It will be 4 x 640gb in raid 10.
Here is the lighting i got for my case,
NZXT Sleeved LED White - 2meters.
Has 3 modes of brightness, just has different resistors on the backside, you could most likely change out a resistor to one of less ohms and get it even brighter, but im not going to do that.
I am replacing the top 120mm fan as well, this is a picture of the original one with the chrome fan grill.
Here is what it is going to look like when i install the new fan and
fan grill i got. The grill matches the top mesh that pops on the case, pics of that later.
And this is what
the new fan looks like when its on.
Replacing Case LEDs
And done. From
blue LED to
red. Will match my case now. I just need to sand the top of the LEDs to diffuse the light and it will be all set.
Used a metal file and grinded down each side of the LED, looks much better and will not have as much of a spotlight effect when its installed in the case.
I received my single sleeve cables from performance pcs, the sleeving matches exactly the cabon fiber sleeving i bought at frozencpu. One thing to be weary about is that in the
description it states:
"Sleeve Color: Carbon Fiber
Heatshrink Color: Carbon Fiber
Connector Color: Carbon Fiber"
When in fact the heatshrink color and connector color are actually black and just the sleeving is carbon fiber. I prefer this way luckily, but its a good thing i didnt want the grey ends.
Looks like a lighter / chrome black, it looks great in person
The warzone, dropping in my mobo, psu, hard drives and running some wiring.
Preliminary install, no cards, no zipties, no heatsink
Prelim with window on, im keeping the plastic on window until its complete to avoid fingerprints and scratches.
I installed my white LED lighting and it looks GREAT! but i dont want to post pics until they are the final ones. Lighting came out perfect.
My CPU, heatsink, and cards arrive today!
"07/19/2011 07:00:00 OUT FOR DELIVERY
"07/19/2011 14:12:00 DELIVERED[D]"
I need to get out of work
Got my box!
This is what was inside
2x Video Cards
Zalman heatsink
and Core i5 2500k
Zalman heatsink installed, man do i hate mini instruction manuals written in engrish. What a pain!
Took me about 30-45 mins to sleeve and install this, looks great though.
My motherboard has a routing route for the heatsink cable, it works nicely. Hard to tell, but if you look from the top down of the motherboard you wont be able to see the pwm cable at all.
The two beasts!
Raid 5 Setup, Windows 7 installing!
Pics of the LED swap, RED looks great!
Current low load temps are at around 27 degrees and cooler @3.3v
I am happy with those temps, plus the zalman look perfect in the case.
Okay, i had to get a new PSU to power this machine, my 750w wasn't cutting it. Here is my new one, just got it in.
Unboxing
Quick DOA test
Now i can install this all sexy-like tonight and finish up the case.
New PSU install
Headphones Arrived! Sennheiser HD 595
Soon i will be doing sound testing from an audiophile in training perspective.
Sennheiser HD202 Vs. http://www.amazon.com/Sennheiser-HD-202-Dynamic-Headphones/dp/B000065BP9]Sennheiser HD595[/URL]
Onboard Vs. X-Fi Titanium Vs. X-Fi Titanium HD
Log continued below
