1 - 20 of 362 Posts
Silverstone Raven Owner's Club
Discussion Starter · #2 ·
Silverstone Raven Case Models
Raven RV01
Official Website
http://www.silverstonetek.com/raven/products/index.php?model=RV01&area=en
Specifications
Material: Reinforced plastic outer shell, 0.8mm Steel body
Color: Matte black
Motherboard: SSI-EEB, SSI-CEB, Extended ATX, ATX, Micro-ATX
External Drive Bay's: 5.25" x 5
Internal Drive Bay's: 3.5" x 6
Top Cooling: 1 x 120mm exhaust fan, 950rpm, 18dBA
Bottom Cooling: 2 x 180mm intake fan, 700rpm, 18dBa
Expansion Slots: 7
Front I/O Port: USB 3.0 x 2 (backwards compatible with USB 2.0), audio x 1, MIC x 1
Power Supply: 1 x optional standard PS2(ATX)
Expansion Card: Compatible with expansion cards up to 12 inches, width restriction-7.09"
Limitation of CPU cooler: 170mm
Limitation of PSU: Unlimited
Net Weight: 15.0kg
Dimension: 280mm (W) x 616mm (H) x 660mm (D), 113.8 liters
Raven RV02 / RV02-E
Official Website
http://www.silverstonetek.com/raven/products/index.php?model=RV02-E&area=en
Specifications
Color: Matte black
Motherboard: SSI-CEB, ATX (maximum 12" x 11"), Micro-ATX
Internal Drive Bay's: 3.5" x 5, 2.5" x 1 for SSD
Bottom Cooling: 3 x 180mm intake fan 700/1200rpm, 18/34dBA
Expansion Slots: 7
Expansion Card: Compatible with expansion cards up to 12.2 inches, width restriction-6.85"
Limitation of CPU cooler: 169mm
Net Weight: 12.5kg
Dimension: 212mm (W) x 503mm (H) x 643mm (D), 68.6 liters
Raven RV03
Official Website
http://www.silverstonetek.com/raven/products/index.php?model=RV03&area=en
Specifications
Color: Matte black
External Drive Bay's: 5.25" x 7
Internal Drive Bay's: 3.5" x 10 (6 from 5.25" adapters), 2.5" x 2 for SSD
Front Cooling: 4 x 120mm fan slot
Rear Cooling: 1 x 120mm fan slot
Side Cooling : 1 x 120mm fan slot
Top Cooling: 1 x 120mm exhaust fan, 900rpm, 18dBA
Bottom Cooling: 2 x 180mm AP181 fan 700/1200rpm, 18/34dBA (compatible with 3 x 120mm fan)
Expansion Slots: 8
Power Supply: 1 x optional standard PS2(ATX), depth limit 180mm
Expansion Card: Compatible with expansion cards up to 13.58 inches, width restriction-6.61"
Limitation of CPU cooler: 163mm
Limitation of PSU: 180mm
Net Weight: 11.4kg
Dimension: 235mm (W) x 522mm (H) x 570mm (D), 69.9 liters
Raven RV04
Official Website
http://www.silverstonetek.com/raven/products/index.php?model=RV04&area=en
Specifications
Material: Reinforced plastic outer shell, Steel body
Color: Matte black
External Drive Bay's: 5.25" x 2
Internal Drive Bay's: 3.5" x 7 (2 hot-swap), 2.5" x 4 for SSD
Front Cooling: 2 x 180mm AP181 700/900/1200rpm, 18/34dBA (backwards compatible with 3x 120mm fans)
Rear Cooling: 1 x 120mm fan slot (optional)
Expansion Slots: 8
Expansion Card: Compatible with expansion cards up to 13.3 inches, width restriction-6.69"
Limitation of CPU cooler: 165mm
Net Weight: 10.9kg
Dimension: 219mm (W) x 581mm (H) x 497mm (D), 63.2 liters
Extra: Supports two Kensington locks
Owner's List
SST-RV01B
1. Plankton4906
2. alext72888
3. Myka
4. maynard14
SST-RV02B-W / SST-RV02W-EW
1. CtrlAltElite
2. SDBolts619
3. HesterDW
3. ixsis
4. Brodda-Syd
5. nismoskyline
6. rRansom
7. LiL_JaSoN
SST-RV02W-EW ( RV02-E White )
1. khemist
2. mark_thaddeus
SST-RV03B-W (black, champagne trimming + window)
1. MPXx
2. chris-br
3. nightfox
SST-RV03B-WA (black, grey trimming + window)
1. Qu1ckset Build Log
2. Maximization
3. Booty Warrior
4. paulyoung
5. Murph619
6. Kryshek
7. francisw19
8. Vendari
9. Ednilson Luna
10. keith6945
11. l8nytalumni
12. ThundaFresh
SST-RV04B-W (black + window)
1. a11an
2. Brodda-Syd
3. Vendari
SST-RVZ01B
1.CaptainZombie
SST-RV05B / SST-RV05B-W
1. Vengeance0058
2. Qu1ckset
3. fix0r75
Please post pic of your build and i will gladly add you to the list, and provide links to build logs and i will also add them to the list.
Ive had my RV03B-WA since beginning of summer, and have plenty of different layouts and mods since then, and i will most some of my different configurations.
This is the current status of my build, waiting on my motherboard which should be here friday!
Discussion Starter · #6 ·
Updated
Originally Posted by Maximization View Post
Got my SST-RV03B-WA up and running a few days ago.
So what are your specs on that?
Did you end up putting fans in the drive bays?
INTEL I7 3820 QUAD CORE CPU ASUS RAMPAGE IV X79 MOTHERBOARD 64GB DDR3 G-SKILL MEMORY RAM
ANTEC 920 Kulher
SEASONIC 850 WATT
500 gb wd velorapter.
diamond 7870 ati video
Vista 64 uiltimate
I did use the top 4 bays to install the Closed loop cooler. Intake push pull into case. I am still tweaking and working on getting all software issues resolved from the transfer from my opteron 185 socket 939 system. The case is a flawless design so far in my opinion.
Discussion Starter · #8 ·
ANTEC 920 Kulher
SEASONIC 850 WATT
Vista 64 uiltimate
not bad, you should fill out your sig with the rig builder. and ya coming from a RV01 and FT03, i think the RV03 is perfect, LOVE the cable management1
Waiting for new vga.In the right side have 3 mechanical hdd"s and in the back the primary ssd.
Sorry about the quality the digital camera run out of energy
Specs on signature
Oh btw is the SST-RV03B-W (black, champagne trimming + window) version.
Discussion Starter · #11 ·
Updated
Originally Posted by chris-br View Post
Add me.
which version do you have?? champagne or grey trim?
Discussion Starter · #16 ·
Updated
Originally Posted by rocstar96 View Post
Why not include all in the Raven lineup?
You know what that actually sounds like an awesome idea, and i will change the thread to a all Silverstone Ravens thread, but probably wont get till Saturday or Sunday because there is alot of info im going to have to get on all the RV01 and RV02 models, just got home from rebuilding my friends computer, and i will be using most of tomorrow evening and Saturday putting my sig rig back together, my motherboard finally arrives tomorrow!!!
Originally Posted by Poisoner View Post
you didn't state which color case you have and how come the rv03 isn't in your sig rig?
Discussion Starter · #18 ·
Here is my updated build, just need to change the lighting
· Custom Loop Snob
Originally Posted by Qu1ckset View Post
Updated
I don't like putting stuff in my signature. The old website version was easier
1 - 20 of 362 Posts
