Hey guys, I am looking to upgrade my GPU.
Do you think the Gigabyte GeForce ® RTX 2080 will fit in the RVZ01?
Silverstone chose drive space, slim optical, and 2.5" drives by default, although you can fit 3.5" drives if you remove the default drive bays. Fractal chose fans. You decide which is more important.Is there any reason why despite the similar layout while Node 202 could accommodate 2 extra fans for the GPU?
Awesome! Your 3d printed CPU duct is exactly what that case needs! Would you be willing to share the file? :specool:Hi All,
Over the last few months I've been building myself a new portable desktop in the ML08 case. I started this after finding a great priced M-ITX bundle on Ebay, containing an i7 7700, Asus Z170I Pro Gaming, 16GB Ballistic Elite RAM, 120GB Samsung M.2 SSD, and a Noctua NH-L9i cooler. Suspect the low price was due to an issue with the Mobo not remembering BIOS settings and the previous owner getting annoyed, but this was easily fixed by re-soldering the battery connector and applying some hot glue.
A few months on I have finally got all of the other components I wanted for the case, and have modded it to support a 3.5 HDD in one of the SSD spaces, and added an SD card reader on top. The PSU I'm using is a Corsair SF450 and the graphics card is a Gigabyte GTX 1060 I had in a previous system.
(HDD mounted using 3D printed parts. Had to drill extra holes in the case for mounting the right side, as well as the new 2x 2.5 bay. 2.5 HDD was just used in this shot for sizing)
(Modded the card reader to connect to the internal USB 2.0 header, and gave it a nice 3D printed enclosure. Also comes with a USB port that I use for my wireless keyboard dongle)
Now it is built and I am doing testing, I am noticing that the temperatures are quite high (getting 80c on both the CPU and GPU). I did my research when getting this case, so am not surprised by this, however as I have been modding it anyway I would like to see how much things can be improved by. On the GPU side I've got 3x 80mm slim fans on order to do the top exhaust mod I have seen a lot of members on here do, but on the CPU side I am unsure what's the best direction to go in.
As I already have an NH-L9i are there any mods that can be done to it to improve matters, or would it be better to just get a new cooler and try and sell it to get some of the cost back?
On the modding side I did a quick 3D print of a fan duct and can definitely feel it pulling air in from the side of the case (even with dust filter on) versus without, but I haven't done any systematic tests on temps/noise yet.
Really interested to hear your thoughts on this!
The easiest fix is to buy a flexible riser. That's what I'm planning on doing.Hi guys, I need help! I have an rvz03 with a gtx 1060. I picked up a sweet deal on an RX 590 sapphire. I checked the measurements and it should fit no problems.
After removing my gtx, I slotted the 590 into the GPU bracket/holder. The bracket lined up fine but the 590 pcie connector won't reach the risers connection! What have I done wrong here or will this card just not fit? Is there a way to adjust the pcie connector on the riser so it's higher up for me to connect the 590?
The easiest fix is to buy a flexible riser. That's what I'm planning on doing. /forum/images/smilies/smile.gifHi guys, I need help! I have an rvz03 with a gtx 1060. I picked up a sweet deal on an RX 590 sapphire. I checked the measurements and it should fit no problems.
https://www.amazon.com/EZDIY-FAB-Express-PCIe3-0-Flexible-Extension/dp/B01CEKN5VO
