I wanted to ask this to x570 owners, I have a Fatal1ty AB350 itx/ac, everything works perfectly with both riser cardsIssues with riser cards?
Sounds like you're gonna have to order from the USHey guys,
firstly great forum, it was extremely helpful when building my ML-08B build and the creativity here is amazing.
have any of you had any luck replacing the GPU Riser cards? mine had a mishap during the last cleaning and silverstones response to how can i buy a replacement was we have no office in australia.
most of the cards i can find online are right angle connectors or cables.
while the gpu (rX480) still works , its very precise on its placement otherwise it wont initialize past the windows login.
any tips to the right direction would be very helpful.
You can order directly from Silverstone Taiwan. At least that's what I did when I melted the pins on my riser card. You can contact Laney Huang. Her email is [email protected].I wanted to ask this to x570 owners, I have a Fatal1ty AB350 itx/ac, everything works perfectly with both riser cards
Hey folks, I recently upgraded my graphics card to a 2070 Super. I’ve later discovered that Turing has issues with riser cards. Anyone using an RTX model? How has it been? I have the original RVZ01
Hello all. Returning to this thread after a while! It's time for my trusty 3770k rig to receive a rather large upgrade. I'm going 8700k and a 2070 Super (16GB 3200RAM).
The i7 is already de-lidded and lapped and will be sitting under a H55 cooler, liquid metal TIM and i'm going to swap the fan out with a Noctua NF-A12x15 PWM, Premium Quiet Slim Fan. My question is.. it this combo of cooling still the best choice or are there better options out there? Has anyone hit 5ghz @ 1.3v without overheating?
Failing the above i'm tempted to build in a Phanteks evolv shift and a much beefier single fan AIO.
I replaced the stock Scythe fan with a Noctua NF-A12x25 PWM. There's no case fan above the motherboard. I have two intake fans for my RTX 2070S, be quiet! Silent Wings 3 PWM high speed fans. I have those spinning a bit more aggressively to help keep the GPU cool because the GPU fans get much, MUCH louder. My temperatures probably aren't the best, but they're never a problem and my system is fairly quiet.Went for the big Shuriken 3 in the end.
My question is about the case fan placement above the Shuriken. I didn't think I would have room but it turns out there is, albeit 1 or so MM. So should I put the case fan above it?
Venting or intake? If its intakeing its going to be blowing straight down on a fan that's venting? So seems to make more sense to vent?
Edit: Settled on having the 15mm in the case with an intake layout. Have to set the fan curve a little more aggressive that I would like as its noisy, but going up to 80% keeps the temperature at 70c maximum.
