Hello! Welcome to the Silverstone SFX Owners Club @ OCN!! If you would like to join the club, post some pics and description of your build. I went ahead and created this this thread for discussion of the Silverstone SFX PSU's which do not have any dedicated threads here on OCN.
ST30SF
As the standards bearer of SFF (small form factor) cases and SFX PSUs, SilverStone has released a reference power supply design for the masses in the ST30SF, a 300W SFX unit designed with high affordability and great performance. It has 80 PLUS Bronze level efficiency and a semi-fanless design that raises the efficiency level for this wattage class and allows for unprecedented low noise operation in low loading conditions.
ST45SF
After successfully revolutionizing both HTPC and SFF market segments with innovative chassis designs, SilverStone engineers continue their push for advancement in these categories by releasing a true upgrade-worthy small form factor power supply, the ST45SF. This SFX unit is compatible not only with chassis that use SFX power supplies but also in smaller ATX chassis with the included adapter bracket. Despite its small size, the ST45SF has features that one would expect from an elite ATX power supply such as 80 PLUS Bronze level of efficiency, temperature controlled fan, 50℃ temperature rating, and reliability for 24/7 operation. Enthusiasts oriented features are also present with single +12V rail and 8pin/6pin PCI-E connectors to fully support multi-GPU systems. For SFF users and for SilverStone, the ST45SF is more than just an upgrade, it is an important milestone for the DIY desktop computer.
ST45SF-G
After successfully expanding and leading SFF(small form factor) cases and SFX PSU into the DIY (do it yourself) market, SilverStone engineers have continued their push for advancement in these categories by releasing a true upgrade-worthy small form factor power supply, the ST45SF-G. Despite being half the size of a regular ATX power supply, the ST45SF-G can still produce continuous power output of 450W. Its 80 PLUS Gold level efficiency is a great leap from the previous SFX best of 80 PLUS Bronze and the full modular cables is also the first of its kind for this form factor. To enable users to easily take advantage of this excellent SFX power supply, an adapter is included to convert ST45SF-G to mount in any ATX case in addition to ones that fit only SFX. For SFF users and for SilverStone, the ST45SF-G is more than just an upgrade, it is an important milestone for DIY desktop computer.
SX600-G
After releasing the breakthrough SFX power supply in 2012 with the ST45SF-G, SilverStone has pushed the technical envelope even further with yet another industry defining design in the SX600-G. This small form factor PSU has the exact same dimensions as its predecessor but its power density has increased from 567W per liter (in the ST45SF-G) to 756W per liter. The result is a standard-sized SFX PSU with an incredible 600W of continuous power, a level that is capable of supporting any single graphics card system with ease. Besides the power increase, the SX600-G comes standard with flexible, flat modular cables similar to those in the PP05-E short cable kit for vastly improved cable management in smaller cases. It also has added semi-fanless capability that was first introduced to SFX PSUs by the ST30SF so its quiet running fan can remain turned off during ideal low load or idle conditions for complete silence.
SX600-G Disclaimer - Noiseblocker fan mod for the 450W will NOT work on the 600W. The 600W unit's fan controller uses a 0-5V range instead of the 0-12V range of the 450W so that fan in the 600W will not spin fast enough and it'll overheat. Credit: Aibohphobia
SX500-LG (COMING Q4 2014)
Club Rules
1: Add picture(s) of your rig.
2: Please respect other members.
Club Members
Once a member of the club and you want to represent us, add the following to your signature copy code below and paste in your profile settings
ST30SF
ST45SF
ST45SF-G
SX600-G
- 500W with 40A on the 12V rail
- SFX-L form factor: 125 mm (W) × 63.5 mm (H) × 130 mm (D)
- 120mm fan
- Semi-fanless to 41°C with max fan speed of 1500RPM (unknown if this has changed considering the fan has changed from the original design)
- Fully modular and comes with PP05-E cable kit
- Gold-rated efficiency
- OEM is High Power/Sirfa
Club Rules
Club Members
Aibohphobia - SX600-G
Zebeyo - SX600-G
ejohnson - ST45SF-G
Wisk - SX600-G, 2xST45SF-G, ST45SF and ST30SF
soundx98 - ST45SF-G (V1.1)/ST45SF-G (V2.0)
Zebeyo - SX600-G
ejohnson - ST45SF-G
[CENTER][URL=http://www.overclock.net/t/1519061/silverstone-sfx-series-psus-st45sf-g-sx600-g-owners-club/0_40]:clock: Silverstone SFX Owners Club :clock:[/URL][/CENTER]
