Hello! Welcome to the Silverstone Sugo SG08 / SG08-Lite Case Club @ OCN!! The SG08 case has been around since 2012 while the SG08-Lite released in Feb. 2014 without a dedicated case club here at OCN. Owners of this case are using this as a dedicated HTPC case while others are using it as a gaming rig. If you would like to join the club, post some pics and description of your build.
Introduction:
SG08
To further increase the appeal of the groundbreaking Sugo SG07, SilverStone engineers crafted a follow-up version in the SG08. For the first time in a SilverStone product and likely also the first for Mini-ITX, a 1cm (0.4 inch) thick extruded aluminum was used to adorn the front panel of a chassis. Finished with fine brush surface and anodized, the SG08's front panel rivals the best home theater equipment in quality and style. The award winning and proven features from the SG07 remain such as the Air Penetrator AP181 fan with dual speed switch, easily removable fan filter, positive pressure layout, and the included 80 PLUS Bronze certified 600W power supply. While compact in size at only 14.8 liters, the SG08 is still capable of accepting a healthy selection of full size components. Even the longest consumer graphics cards that are up to 12.2 inches can fit. This extraordinary capacity, along with the cooling power provided by the built-in AP181 fan, makes the SG08, along with SG07, the ultimate Mini-ITX chassis.
SG08-Lite
For years, SilverStone Sugo series has been the benchmark and the standard for high-performance Mini-ITX chassis. The SG08-LITE was designed to retain all the signature features from the award-winning SG08 such as the compact 14.8-liter design that can accommodate graphic card up to 12.2" and the premium 10mm aluminum front panel where SilverStone engineers have further updated the slim optical slot into slot-loading variety for cleaner styling. Its specially designed fan bracket offers the users flexible cooling options for 180mm fan or 120mm/140mm fan with water-cooling radiator. To keep dust out, all intake vents are equipped with removable filters for easy-cleaning. In contrast with its relatively small size, the SG08-LITE supports standard ATX PSU for greater selections and when used with SilverStone's Strider Gold S series, the smallest full modular power supplies with 80 PLUS Gold in the world, or our carefully engineered SFX PSUs, the SG08-LITE can help you create an incredible Mini-ITX system.
SG08: http://www.silverstonetek.com/product.php?pid=317&area=en
SG08-Lite: http://www.silverstonetek.com/product.php?pid=484
Recommended Components
Club Rules
1: Add picture(s) of your rig.
2: Please respect other members.
Club Members
Once a member of the club and you want to represent us, add the following to your signature copy code below and paste in your profile settings
Introduction:
SG08
- Thick 10mm aluminum front panel with premium styling
- Class leading SFF chassis with 180mm fan and positive pressure cooling
- Ample space for CPU cooling (117mm in height)
- Elevated standoff for motherboard back side components
- Support for two 2.5" SSD/hard drives and one 3.5" hard drive
- Includes 80 PLUS Bronze certified 600W@50℃ PSU with single +12V rail
- Adjustable VGA fan duct for improved cooling efficiency
- Removable fan filters included for case fan, PSU, and VGA duct
- Support graphics cards up to 12.2 inches and 400W
SG08-Lite
- Ample space for CPU cooling (147mm in height)
- Elevated standoff for motherboard backside components
- Fan bracket supports 180mm fan or 120mm/140mm fan + water cooling radiator
- Removable fan filters included for case fan and PSU
Club Rules
Club Members
Hybster
minnus
minnus
[CENTER][URL=http://www.overclock.net/t/1485033/silverstone-sugo-sg08-sg08-lite-owners-club/0_40]:clock: Silverstone Sugo SG08 / SG08-Lite Owners Club :clock:[/URL][/CENTER]
