It's been a while since I had mine set up, but I did use a 140mm CLC when I was running the SG08 (I re-found this thread as I'm helping a friend set up a new PC and I'm pushing him to go SFF, and I have fond memories of my SG08 [still in my closet, waiting for the right moment to pounce now that SLI is dead[).140mm fan. IS it possible to install 140 mm fan on top? According to Silverstome - yes. But in reality - I can't.. The holes is simply doesn't match . Does anyone havve experience in replacing 180 mm on 140 mm fan? 120 and 180 are matches.
Hi! Sorry for my English, I'm writing from Russia.Hey guys, stupid question (!!)
I've googled and I recall discussion about an absoloute max clearance of 117mm for the cooler, on this forum, I'm pretty sure I've discussed it before.
Does anyone recall, if that's 117mm WITH the giant 180mm fan staying in the system, or by removing it? (I'd prefer to keep it)
Here's the choice of coolers I can pick from.
I am VERY annoyed that PC Part Picker, once recommended me a cooler which was incompatible with my tall memory.
Does anyone know which one of those coolers is best for memory clearance too?
Hi! Did you manage to install 3-fans videocard in SG08? I'm thinking about upgrade my current RTX 2060 (2-fans) and the size and fit is main concern. Also the thickness of the card can be a problem - it can get caught in the case of the power supply.The EVGA GeForce GTX 3070 X3 ULTRA GAMING graphics card works in passive mode in idle mode.
Sorry, I've already replaced this case with another one. There are no photos with a video card in the case. Find me on ixbt.com (Coolbits).Hi! Did you manage to install 3-fans videocard in SG08?
Would be nice to see you photos.
