I suggest you use TeamViewer.
For you:
For your aunt:
Directions:
All you have to do is have her download the teamviewerqs.exe and then have her tell you the numbers/letters that are in the username. From there you type that into your box that says username and then press enter and then it'll ask you for a password. Type in the password your aunt gives you. It's underneath the password on your aunts password.
For you:
For your aunt:
- Windows: http://www.teamviewer.com/download/TeamViewerQS.exe
- Macs: http://www.teamviewer.com/download/TeamViewerQS.dmg
Directions:
