My bios is listing my RAM at 1237Mhz but they are rated for 1600Mhz. (I would like to ensure they are running at proper speeds etc.. I dont plan to OC them, just the CPU)
Can I simply change the RAM freq. setting and all is well... or do I need to change voltage and such?
I am also planning on OCing my AMD 1090T CPU. If I do so will that effect the RAM settings or is that something seperate?
Please and thank you.
