1 - 14 of 14 Posts
Hi<br />
<br />
I'm repairing a very old computer for a friend of mine, but I have a prob.<br />
He wanted win xp on it, so I did that.<br />
But I can't find any driver for win xp for the graphics card...<br />
it's a sis 6326 pci video card.. I can only find win 98/ME drivers...<br />
Can anyone help me please?<br />
<br />
Thanks<br />
<br />
Larezz
Administrator
What are the full specs of that system please <br />
<br />
try here : <a href="http://www.softwarepatch.com/utilities/sis6326.html" target="_blank">http://www.softwarepatch.com/utilities/sis6326.html</a> <br />
<br />
Heres the latest driver : <a href="http://www.majorgeeks.com/SiS_6326_Display_Driver_d3951.html" target="_blank">http://www.majorgeeks.com/SiS_6326_D...ver_d3951.html</a>
duron 800mhz, 256 sdram 133mhz<br />
mobo: <img src="http://img139.imageshack.us/img139/7382/shothf7.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" />
Discussion Starter #5
Both given drivers don't work..
Discussion Starter #7
That's 5 euro's, paying by credit card <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Discussion Starter #9
I realy can't find any driver that works..<br />
could it be that that card just can't work properly in win xp?
Can you show us a screenshot of his device manager?<br />
<br />
Edit: Try this maybe? <a href="http://www.driverscollection.com/gf.php?file_id=14169&sid=304314030" target="_blank">http://www.driverscollection.com/gf....&sid=304314030</a>
Discussion Starter #11
Not working, the driver..<br />
Windows says dat the driver is ok.. that's the problem.. Neather driver will work 'better' than current, windows says..<br />
in the device manager there isn't a remark at video card, all is normal windows thinks..
If windows thinks the driver is fine, you should be able to force it to use a specific driver.<br />
<br />
Remove the device from the device manager...when it asks to reinstall a driver(which it should), don't let it search for anything. Manually point it to a folder with a compatible .inf file, and it will use that.
Reactions: Larezz
Discussion Starter #13
Yes I know, but i automatically uses the other 'driver' which doesn't even properly work.. big windows bug <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile"><br>
But I set the hardware rendering to none and now there almost isn't any ****** in screen showup... but what ever, it's only for ms word use and internet surfing, no pro use so it won't anoye them I think<br><br>
To everybody, much thanks for helping me with this, I really appreciate it!<br>
Larezz
1 - 14 of 14 Posts
