Sisoft
282 5
Hey there guys..well i got my new cooler and i was wondering if it would be a good idea to run a burn in test to get the as5 going ?
1 - 6 of 6 Posts
Prime95 would probably work better since you can run it as long as you want. Plus I have never likes the Sandra burn in wizard.
Yeah all you are trying to do is heat cycle the as5... You want to make sure you get heat and some cooling cycles in between.
1 - 6 of 6 Posts
