Good morning!
I am planning on redoing my loop and am currently in the process of buying more acrylic tubing (3/8in ID, 1/2in OD) and ran into a slight problem last time I was bending the tubing. The silicone insert that I bought specified it was for 3/8 ID acrylic tubing, but it did not fit very snug inside the acrylic tubing. I remember someone posting something last year about a similar issue and using a larger silicone flex tube, but I can't remember how much bigger they went up. I was wondering if anyone else ran into similar problems and how they rectified the situation whether it be increase the size of the silicone inseter, and if so, what size silicone insert did you use?
Thanks in advance!
Thanks in advance!
