Skylake Overclocking Guide
Haswell Overclocking Guide [With Statistics]
Skylake Overclocking Guide [With Statistics]
Welcome to the Skylake Overclocking Thread. Because a lot of people found my Haswell Overclocking Guide to be a useful source of information, I have decided to try my hand at a Skylake guide as well. For those new to Overlock.net, know that you can open an image in a new tab to view it in its actual size.
Unlike Haswell, Prime v28 and Linpack are no longer much hotter than other tests. They are still the hottest tests around, but it's not quite as ridiculous anymore. For example, Prime v27.9 is similar in temperature to v28.7, As the settings chart notes, I detected temperature fluctuations in Linpack, IBT, and XTU stress even though the load on the CPU still read 100%.
Just like in Haswell, note how XTU stress is cooler than XTU bench, and AIDA64 varies in temperature wildly based on the settings checked. Without a way to loop the test, applications like XTU bench and Cinebench are not viable stress tests. As expected, custom x264 at 16 threads is hotter than the 4 thread setting, and using more memory for Linpack causes a hotter test. With the Haswell temperature chart I had 8gb of ram to use, and for this chart here I had 16gb.
My temperatures are lower than what most people will observe because I am not running hyperthreading and I am also delidded. My case as good airflow. Hyperthreading will cause a chip to be hotter and harder to pass stress tests.
Below is a hierarchy of stress tests, listed in order from hardest to pass to easiest to pass. For time-to-crash data, please visit the 'Miscellaneous Testing' spoiler. Anything that is counted as easy to pass or even easier are not recommended and will not be enough to be entered into the main overclocking settings chart. More details in the charting form spoiler.
Marathon-Man:
OCCT S
Linpack (Max) (From Intel's website, not from OCCT or any other place or XTU.)
P95 28.7 S
Tough:
P95 27.9
IBT (Max)
Medium:
x264 16T
ROG Realbench
Easy:
Stockfish (Chess, BMI2 version)
XTU
Aida64 (Full Suite)
Walk in the Park:
Cinebench
Firestrike
Booting into Windows
x264 is the recommended and the default go-to stress test for this thread. If you feel the need to use a hotter test that is your right, but know that your overclock may be hampered by that choice. You could forego delidding in many cases simply by switching to x264. The downside to this method is that the overclocking process will take longer because we are replacing a very stressful program and a short test duration with a less stressful one and a longer duration.
I highly recommend trying our x264 encoding test if you are looking for a test that can stress while still being pretty cool. For a peace of mind I recommend running x264 looped all night as you sleep once, and if it passes, it's stable. Run it, sleep, wake to see the test still running, pass, smile.
Angelotti and JackCY have tweaked the x264 Bench utility and turned it into a stress testing tool. You no longer need to download other programs to get it to work; just download, unzip and run. Simply put, our version of x264 test is better in every way to the original x264 benchmark. There is no reason to use the original utility. There is a readme inside to tell you what options to pick but I will also summarize it here: By default, try the 16 thread setting (yes, even if your CPU is an i5) with normal priority.
'Prime95 is not Certified for Haswell/Skylake/Insert Nonsense Here'
This was a myth that was perpetuated by some Youtubers. For Skylake it seems this has died down. But know that Prime95 will not eat your CPU and spit out the remains.
Prime95:
When you are closer to stability, Prime95 may stop with an error. This is a rounding error, meaning the crash was minor enough so that your computer itself does not crash. There is some data to suggest that Prime95 gives out rounding errors very frequently, even in overclocks considered functionally stable. With Skylake, unlike Haswell, version 28.7 is not significantly hotter than version 27.9. Still, from testing thus far, v28.7 has been shown to crash unstable overclocks faster than 27.9, so consider it a harder test.
There isn't conclusive evidence so far about which setting in Prime is the most stressful and prone to crashing unstable overclocks. It is known that smaller FFT sizes tend to cause higher temperatures. 8 is the smallest size (in K, but that's a technicality). It is unknown if using more memory causes unstable overclocks to crash faster. Here is a picture showing how to set your own FFT size:
Linpack/IBT
Linpack is a newer version of IBT. Please note that with larger ram usage settings, it will take a while for the memory to be used up and the temperature to increase. This may take 2 minutes or so.
Below among the list of stress test download links there is a link for "Linpack Package". I have taken Linpack and added Linx GUI to it. You can now use Linpack as Intel originally intended or run the GUI to easily change the test settings.
Stress Test Download Links
Custom x264 with Loop Functionality and Other Improvements v2.06
Aida64 v5.30.35
IBT v2.54
Linpack Package v1
OCCT v4.4.1
Prime95 v27.9
Prime95 v28.9
ROG Realbench v2.4
XTU v6.0.2.2
y-Cruncher 0.6.8
Latest Version of HWinfo (Monitors temps, voltages, etc.)
Memtest v6.2.0 (For testing ram overclocks.)
'I must pass all stress tests!'
So if I made a program that crashes you at stock clocks, you would feel compelled to underclock your CPU, even if that application in no way represents real-world usage? Passing "all stress tests" really means passing "all stress tests that people happen to have made". If nobody decided to make ultra-mega-Prime95, you would think your overclock is stable. That seems like a random, haphazard way to figuring out if your overclock is stable or not. Computers are built for using, and whether you crash at Prime95, what really matters is whether you crash often enough while using it normally. Forcing yourself to pass a stress test "just in case you use it to its limits" makes no sense either. No point in going down "what ifs" which have no signs of ever happening. And if it does, work it out when it does.
Run 2 different types of stressing programs, and then use your computer normally. If you crash, then it's not stable. What's stable for you might not be stable enough for me. Some people need 100% reliability because of their jobs.
Let's not get into a semantic debate about the word 'stability'. If you define stability as 'never crashes on anything, ever', then I don't care about your notion of stability. That criteria makes no sense either because the only way to be sure you are stable forever is to test your CPU forever. The world doesn't end if your CPU crashes on you. Run a stress test overnight, then go play video games to test things out. If you ever end up crashing in the heat of the moment, lower the multiplier by one and you should be perfectly stable.
Miscellaneous Settings:
It is recommended by Asus to disable 'spread spectrum' and 'CPU SVID Support' in the UEFI when overclocking. Please note that disabling SVID support disables adaptive voltage. In order to get Cstates to work correctly with an overclock, you need to have adaptive voltage mode on.
Click here to view the Skylake Overclocking Chart in a new tab!
https://docs.google.com/spreadsheets/d/1wQwYMGsSnMpKxrEesNVUSoP7hGykFWw1ygJsxwx64e8/edit?usp=sharing;output=html&widget=true
I am not responsible if your CPU blows up, your motherboard blows up, your computer blows up, your house blows up, or if your life blows up due to my guide.
My recommendations on what parameters are "safe" are my opinions. I do not have many chips I can subject to high voltages and loads to figure out what is truly safe or unsafe.
What is Skylake?
Skylake is the codename of the microarchitecture launched at August 2015 to succeed Broadwell. The unlocked desktop parts were the first to come out. They are the i5-6600k and the i7-6700k.
How are the 6600k and the 6700k different?
It's the same pattern as in previous generations.
6600k:
Base Clock: 3.5GHz
Max Turbo: 3.9GHz
L3 Cache: 6MB
Hyperthreading: No
Box Cost: $243
6700k:
Base Clock: 4.0GHz
Max Turbo: 4.2GHz
L3 Cache: 8MB
Hyperthreading: Yes
Box Cost: $350
In most cases the L3 cache difference is immaterial. If you want hyperthreading, the choice is obvious but bear in mind it makes the CPU hotter in testing. Will the i7 part overclock better? That remains to be seen. However, if my Haswell Overclock Chart is any indication, the difference will likely be small. If that 100MHz matters that much to you, you should've bought a binned chip in the first place.
What's new with Skylake?
What about the "x20 PCIE lanes" stuff I've been hearing about?
How does Skylake stack up to past generations?
Refer to this lovely chart from PCPer.
(Credits: PCPerspective at www.PCPer.com)
Haswell overclocked to ~4.5GHz and DC maybe ~4.6-4.7Ghz. It's far too early to say what the average Skylake overclock will be. Clock for clock Skylake has an extra large improvement in x264, of about 28% over Snady Bridge. The chart might be using an old version of x264 though. Other sources report 35% gain. In Cinebench however, that lead shrunk to 11% over Haswell and 25% over Sandy Bridge. Broadwell isn't often discussed due to low TDP, probably low overclocking, and the emergence of Skylake.
Quick Word about Temperatures and Delidding:
Intel said that Skylake has a similar thermal solution under the Integrated Heat Spreader to that of Devil's Canyon. The temperatures are also similar to DC when I consider margin of error. However, it still benefits from delidding. Expect 10-13C improvement in temperatures. Lower temperatures can decrease the amount of voltages required to stabilize. By delidding yourself, you are risking permanent destruction of your CPU and resale value of the CPU will decrease even if the delidding went perfectly. You can pay $50 to SiliconLottery to have them delid it for you. This service is insured so that if anything does go wrong, your chip will be replaced.
There are also two types of delidding. You can either choose to take off the IHS, put on paste, and mount the cooler directly onto the die. This is called 'bare-die' and requires a more delicate touch. If the cooler is mounted too tightly you can warp the die and you're toast. If you elect to put the IHS back on, this is the safer method. Bare die isn't a large improvement over putting the IHS back on, so I recommend putting the IHS back on.
Is there any insurance for my CPU?
Yes. The Intel Protection Plan still exists. For $25-$30 you can stop worrying about overclocking leading to death of your CPU. This is on top of the warranty you get with a CPU purchase. Visit here for details. In general people found that Intel has been pretty lenient in accepting replacements.
6600k:
Base Clock: 3.5GHz
Max Turbo: 3.9GHz
L3 Cache: 6MB
Hyperthreading: No
Box Cost: $243
6700k:
Base Clock: 4.0GHz
Max Turbo: 4.2GHz
L3 Cache: 8MB
Hyperthreading: Yes
Box Cost: $350
- No stock heatsink.
- z170 chipset.
- Socket 1151. Past coolers compatible with Sandy Bridge, Haswell, etc still work.
- Neither the CPU nor the socket are backwards compatible.
- Removal of Fully Integrated Voltage Regulator, or FIVR introduced at Haswell due to issues at low power applications.
- Lack of FIVR may mean lower temperatures (although that's just one factor among many) and could mean better response under extremely low temperatures.
- According to Sin from OCN and Raja from Asus, changes in architecture requires less robust power-handling components. Because of this, boards tend to have a lower power phase count.
- DDR4 is standard. DDR3 and DDR3L support very rare, and no motherboard supports both DDR3 and DDR4. Still dual channel memory controller.
- It is believed that the Integrated Memory Controller in Skylake is very strong, allowing very high speeds without compromises.
- A smaller die, thinner PCB, and smaller process than Haswell/Devil's Canyon.
- Generally acceptable core voltage has increased.
- Expect overclocks to be similar to that of DC. (In this guide I will refer Haswell as Haswell and Haswell Refresh as DC.)
- Base clock can be changed in a very fine-grain way. Instead of "straps" jumping for 100 to 125 MHz etc, now you can increase it 1 MHz at a time. It's also possible to deviate from the base clock more without instability. Changing the base clock here has no effect on the DMI. However, it still affects ram and PCIE. In total, this makes BLCK changes a more useful thing to try.
- In a similar spirit, ram overclocking is less granular. What used to be 200/266 MHz steps are now 100/133 MHz steps.
- Power usage is similar enough to DC/Haswell. Temperatures similar to DC.
- Graphics updated to HD 530.
- The Direct Memory Interface has been upgraded to version 3. This bumps up the spec to 8.0 gigatransfers per second.
- There are "20 lanes of PCIE 3.0". 16 are direct lanes to the CPU. If you want more you need to go to the enthusiast platform.
- The remaining 4 lanes are handled by the DMI. In the past you had 2 GB/s cap, now you have 4 GB/s cap. There's still overhead, so in reality you'll get maybe a maximum of 3.5 GB/s. You can now run a single Intel 750 Series ssd without bottlenecks. DMI PCIE lanes have a higher latency than direct CPU lanes but the difference should be minor. You can now RAID PCIE ssds through Intel Rapid Storage Technology, and it can be a mix of NVMe and ACHI drives, although that is not recommended. Procedure remains tricky.
- The DMI upgrade also means you will be seeing a lot of new USB 3.1 ports, with a chance of seeing USB Type-C ports. Of course, if all of those are running at full blast, expect your PCIE SSD speeds to suffer a bit.
- Usually in motherboards, the top PCIE lane is x16 PCIE 3.0 lane, second is the same, and the third full PCIE lane is for the SSD. Since Skylake CPUs only have 16 CPU PCIE lanes, putting a second GPU in means both GPUs run at x8.
Here are some things to think about before the instructions are read:
- Coolermaster 212 Hyper Evo -> Noctua D14 -> x61 Kraken -> Custom Loop
- Do you want to delid?
- Ripjaws 4 were out during the x99 times, which is pre-Skylake. Both Ripjaws 4 and Ripjaws 5 are DDR4 modules, but it is recommended to use the latter. There have been some anecdotal reports of Ripjaws 4 requiring more voltage to be stable on the z170 platform.
- Unlike Haswell, LLC affects core voltage like the pre-Haswell times, and adaptive voltage mode is no longer dangerous under heavy synthetic loads like Prime95.
- On a similar note, input voltage is no longer a setting. Same goes for cache voltage.
- C-states decrease the voltage and in turn power usage during idle. This has a marginal effect on SSD performance.
- The recommended utility for looking at your stats is HWInfo available here.
- Terminology Check:
Uncore = Cache Ratio = Ring Bus (Not technically 100% true, but when people say these things that's what they mean.)
BLCK = Base Clock
100 (Base Clock) x 45 (Multiplier) = 4500MHz or 4.5GHz
Again, changing the base clock affects PCIE and ram speeds. You will have to readjust the ram setting accordingly if you change the base clock.
Skylake is still a new launch. Keep track of BIOS updates. Things may be improved as time passes.
- If you Bsod, you can look at some details from the crash log. BluescreenView will pull up the information for you. If you want, you can download it here.
- VID is the voltage the processor requests. Generally it is not a useful reading in HWinfo. Vcore when read in real-time in a tool like HWinfo is a measurement of the voltage actually given. When you put in 1.3v into core voltage in the BIOS, maybe only 1.25v is given to the cores under load. This discrepancy is called Vdroop. To counteract that you can simply raise the voltage you entered or you can use Load Line Calibration or LLC. This setting impacts the real-time Vcore reading and increases it. Voltage delivered can have very quick drops, so quickly that specialized gear is required to detect it. LLC helps counteract that.
- Can't find Vcore reading in HWInfo? Don't know where F-clock (Fclk) is on HWinfo?
- Whenever possible, change as few settings at a time. If you crash with core, cache, ram, and GPU overclocks enabled, it's hard to tell which overclock(s) caused the crash.
- Increase multiplier by 1 each time.
- The voltage required to stabilize the next multiplier increases each time.
- Write down the settings you've tried for better organization.
Core Overclocking
Skylake comes with far more freedom to tweak than Haswell, but this also means more complexity when you are in pursuit of the absolute best settings possible.
0. Update your UEFI.
1. Manually set your cache ratio and ram to stock. Don't even use XMP profiles. Hell, turn your GPU's overclock off.
2. All Skylake CPUs so far can hit 4.4GHz. Try 4.4GHz at ~1.35v. It should work and be stable. If not, apply 1.4v. Stable? Good.
3. Just go up a multiplier. Increase voltage if you crash during stress testing with our x264 test. Remember, recommended maximum voltage is 1.45v. Never run a stress test and leave without monitoring the temperatures for the first 2 minutes.
4. Eventually you will find the highest overclock you can hit without breaking 1.45v and this overclock will pass x264 test overnight. Another option is to try Prime95 v27.9, but v28.9 is overkill and masochistic. To read more about different stress tests and to access quick download links to them (including out modified x264 test), check the "Stress Testing" spoiler.
5. Decide if you want to tweak the base clock. The next section is all about that. If you don't want to tweak the base clock, continue reading about Fclk if you want a possible 1% boost to your FPS in graphics-related stuff like gaming and skip to ram overclocking and cache overclocking. The sections with a blue title are related to base clocks, but the Fclk section applies to those who want to tweak Fclk without touching the base clock as well.
Blck/Fclk tweaking time!
Blck, or "base clock", affects multiple things including: Fclk, core frequency, cache frequency, and ram frequency. Let's look at each of these things.
Fclk (Optionally with Base Clock Changes):
Fclk is a setting that has to do with the way the GPU contacts the CPU. The default setting was supposed to be 1000MHz, but due to some complications, z170 boards end up having 800MHz as the default setting for the earlier versions of their UEFIs. The ability to adjust the Fclk was added with later BIOS updates. Fclk is a GPU-oriented setting, so CPU benchmarks won't notice a difference. The difference between various Fclk settings is relatively small. It varies depending on the configuration (especially from GPU to GPU), but for a 980ti the difference is within the margin of error. Open the spoiler here to look at Anandtech's results:
800MHz was the original default, with 1000MHz supposedly being the default, but it's possible to overclock this further. From what I can gather, the performance gains of overclocking the Fclk is really quite small, even on graphical benchmarks like Unigine Valley. If the difference in performance past 1GHz Fclk doesn't even show under some graphical benchmarks, the difference is really quite small. However, if you have a GTX 770, this section is for you.
The exact settings will vary because motherboard vendors love assigning different names to the same thing. The instructions below are meant for Asus z170 Hero boards but it should be similar enough to whatever you have to make sense.
Fine tuning Core Clock with Base Clock:
Base clock x Multiplier = frequency in MHz
Recall that multipliers can only be whole numbers. If we only tweak the multiplier, we can only do 4.5, 4.6, 4.7GHz etc. What if I can do 4.5GHz but I cannot do 4.6GHz? Maybe I can stabilize 4.55GHz. To get 4.55GHz we have to change the base clock. The base clock can contain decimals (like 100.1MHz, etc).
So let's say we want to do just that: Apply a 4.55GHz core clock. We know our 4.5GHz overclock is stable and this is our fallback. Let's pick a number that's kind of close to 100 that multiplied by something gives us 4550. 130 base clock with 35 core multiplier will do just that.
Old OC:
100 x 45 = 4.5GHz Core clock
100 x 40 = 4.0GHz Cache clock
2133MHz Memory clock
Base clock set to 130:
130 x 45 = 5.85GHz Core clock
130 x 40 = 5.20GHz Cache clock
2773MHz Memory clock
Base clock set to 130 and multipliers adjusted accordingly:
130 x 35 = 4.550GHz Core clock
130 x 31 = 3.900GHz Cache clock
2080MHz Memory clock
If the above passes, we now have a stable 4.56GHz. Maybe we could aim for 4.57GHz now.
In the example, changing the base clock to 130 causes the core, cache, and memory clocks to be far higher than stock. (Why stock? Because if you were following directions, all of your overclocks should be set back to stock!) Since the cache and ram are now overclocked, we don't know if the new cache and ram overclocks are stable, and if the new settings crash we don't know if it's the core clock, cache clock, or memory clock causing the problem. We must adjust the multipliers to set it back to stock. 31 as the multiplier for cache gives us something close to what it was originally, so we will not crash. Setting the ram back down to close to 2133MHz gets us stable ram once again.
The higher you go from 100 base clock, the harder it is to stabilize. Generally the stability at 170 bclk and up will vary depending on the motherboard. You will sometimes fail to boot if the bclk is too high. There's usually no good reason to set the base clock above 170 though. With smart math, it should be possible to get very close to any frequency without exceeding 150 bclk. Don't forget that bclk can have decimals.
Base Clock Balancing Act:
If you want to adjust the Fclk and ram settings on top of fine tuning core and cache clocks with base clock changes, you have to ensure that:
If you are going to adjust the base clock but don't care about Fclk overclocking, please make sure your Fclk isn't overclocked when your base clock is changing. You can check this in HWinfo as "System Agent" clockspeed.
Ram Overclocking
Once both the core and cache ratio are set to stable and overclocked values you don't want to touch anymore, go ahead and overclock your ram. You now have more fine-grain jumps in frequencies to choose from. Don't forget that timings matter as well, and the "tighter" or the smaller the numbers are, the better. According to Asus, System Agent and VCCIO voltages can help stabilize a ram overclock, although more isn't always better. The ram itself could use some extra voltage. The default is 1.3v, let's bring that to 1.35v which is a safe amount.
Here are rough guidelines for figuring out how your ram is doing for those too lazy to benchmark:
Latency:
Ram can have lower latency or higher frequency. Generally for gaming purposes, lower latency is considered to be more important (unfortunately for you, DDR4 is generally worse in this regard than DDR3). To calculate latency, do 2000 x (Cas/Frequency). Lower is better.
Frequency:
On the other hand, a higher frequency is generally considered to be useful for video editing workloads which do sequential reads. These types of work favors higher frequency. To calculate how long these reads take we do 1000/Frequency. Lower is better.
Anandtech's Rough Ram Performance Formula:
Frequency/Cas = Performance Index
Whichever has a higher performance index is generally faster. If two sets are very close, the higher frequency kit wins.
Cache Overclocking
Cache overclocking is the easiest thing to overclock but has the least impact on performance (comparisons listed in the later sections). By now, everything should already be overclocked and stable except for the cache. Simply set the cache to the same frequency as your core and stress again to check if it's stable. If it's not stable, lower the multiplier by one and repeat. Unlike Haswell, cache can generally get to the same frequency as the core. There isn't even a cache voltage to worry about.
Final Step:
Go back and see if your overclocks still function perfectly with less voltage. How low can you go? This is just fine tuning of your voltages.
Safe Voltages (TENTATIVE):
Vcore: 1.45v/1.4v
VCCIO: 1.25v/1.2v
System Agent (SA): 1.3v/1.25v
Vdimm: 1.4v/1.35v
No Cache voltage or Input Voltage with Skylake
The first value shows voltages a pretty ballsy person can use. The voltage after the forward slash shows voltages for regular users who don't want to live on the edge. Please do not exceed these parameters unless you are a serious power-user that knows what he/she is doing and is willing to accept the risks.
Quick Word About "24/7 Stability and Safety"
24/7 stability is useful for people using their CPU 24/7. Playing video games a couple of hours a day or week is not the same as hammering your CPU at 100% load for hundreds of hours in a row. If you're really that concerned about CPU longevity you shouldn't be using Prime95 to stress. "100% load 24/7 safety" is a meaningless and vague goal people strive for.
There should be a setting to adjust the Fclk directly in your BIOS, allowing you to set the Fclk to 400MHz, 800MHz, or 1000MHz.
For example, in the Asus Hero z170 UEFI, under "Tweaker's Paradise", there is an option called "FCLK Frequency for Early Power On". With all motherboards there is typically an option for 1000MHz. What this setting actually does is set the Fclk multiplier to 10, and if the base clock is 100, 100 x 10 = 1000MHz Fclk. In HWinfo, under "System Agent Clock" (refer to Overclock Preparation spoiler), it should now read 1000MHz.
So, if you choose to only overclock the Fclk through the dedicated Fclk setting, make sure your base clock makes sense. If you have it set to 1000MHz and you forget about it and you go back to changing the bclk to overclock your core clock, you won't understand why you won't POST at 170 bclk. The answer is that your Fclk has been overclocked to an insane value.
So let me state it again: Your final Fclk frequency is affected by both your Bclk and the setting you've chosen in the dedicated Fclk setting.
Fclk setting at 1000MHz (Fclk multiplier = 10)
Bclk set to 100MHz
10 x 100 = 1000
Fclk is 1000MHz
Fclk setting at 800MHz (Fclk multiplier = 8)
Bclk set to 110MHz
8 x 110 = 880
Fclk is at 880MHz
If you didn't pick a Fclk setting and you left it at auto in the dedicated Fclk menu, then your motherboard will try to adjust the Fclk multiplier so that you will not crash.
Bclk set to 100MHz
10 x 100 = 1000
Fclk is 1000MHz
Bclk set to 110MHz
8 x 110 = 880
Fclk is at 880MHz
Old OC:
- Bclk that is not too far from 100 to cause instability.
- Bclk when combined with a core multiplier, gives you the absolute highest core frequency that is stable. (Highest priority, unless using GTX 770.)
- Bclk when combined with a Fclk multiplier (4, 8, or 10) has to result in an overclocked, but stable Fclk.
- Bclk when combined with a right memory divider, gives you a ram frequency that is overclocked somewhat near its maximum.
Ram Overclocking
Latency:
Frequency:
Cache Overclocking
Final Step:
Vcore: 1.45v/1.4v
VCCIO: 1.25v/1.2v
Vdimm: 1.4v/1.35v
Marathon-Man:
OCCT S
P95 28.7 S
Tough:
P95 27.9
IBT (Max)
Medium:
x264 16T
ROG Realbench
Easy:
XTU
Aida64 (Full Suite)
Walk in the Park:
Cinebench
Firestrike
Prime95:
Linpack/IBT
Aida64 v5.30.35
IBT v2.54
Linpack Package v1
OCCT v4.4.1
Prime95 v27.9
Prime95 v28.9
ROG Realbench v2.4
XTU v6.0.2.2
y-Cruncher 0.6.8
I have redone benchmarks to test the performance difference between a high and low cache frequency.
As you can see, a decrease of 100MHz in core clock has a larger impact on performance than a 1,000MHz decrease in cache frequency. Therefore, my position on cache frequency remains unchanged: It is a secondary setting that you should only overclock and worry about once everything else is done.
If you'd like to see Haswell cache frequency testing, open this spoiler.
Credits to Maxforces for the second part of the benchmarks. From my personal benchmarks, I found the drop of 0.7Ghz for the cache to be an equal performance hit of 0.05Ghz decrease in core clock and this difference shows in a very CPU reliant benchmark like chess.
And here are the most recent tests for cache frequency that I have done:
The 4.2 vs 3.4 is the cache setting. The core multiplier for this test was x45.
Testing methodoloy in this test is much more well documented by me.
Chess: Houdini 3, 9mb hash, starting position, 5 minutes.
BF3 Multiplayer: 64 player server in a closed map (Canals). Regular gameplay for entire round.
BF3 Campaign: Second misson, following scripted NPC movement.
Enemy Territory: 30 vs 30, Fueldump.
Runescape: GE, World 3. Capturing FPS while stationary. Max detail, non HTML5. x4 AA Bloom enabled. (It seems to use CPU to do AA)
Oblivion 1: Walk out in the wild, through Oblivion gate, to town gate.
Oblivion 2: NPC combat in Imperial City. Several guards/NPC vs Umbra. Spawn 50 player copies and begin combat once Umbra dies.
These were done on tests, as you can see, that vary from CPU benchmarks to CPU reliant games.
Maxforces Says:
Test setup
Results
but if you play 3dmark you will gain some points
Maxforces Says:
Test setup
Results
Some of my cores are hotter than others. Is this normal?
If the variance from hottest to coldest core is 10C or under, I would call that normal. If it's greater, consider doing a re-paste.
Ram XMP profile doesn't work.
Make sure the motherboard bios has been updated to the latest version. If that doesn't work, try adding a bit more ram voltage, SA voltage, and VCCIO.
Monitoring software shows incorrect data.
Make sure you are using HWinfo and make sure it is the latest beta version.
Prime95 stopped and says there's an error.
Most likely it is a rounding error. This means you've failed the test, but in a more minor way such that the computer doesn't crash. There is some data to suggest that Prime95 gives out rounding errors very frequently, even in overclocks considered functionally stable.
My temperatures are through the roof!
My CPU is downclocking under load!
Check your motherboard's power settings. Set them to max.
The Vcore is far higher than what I've set in the BIOS under load!
Your LLC is probably being overly aggressive. If possible, please set it to a lower amount manually.
- Stop using IBT or Linpack or Prime95. Use our custom x264 test or use something similar like ROG Realbench,
- If your temperatures from core to core vary over 10C, consider a re-paste of your thermal paste.
- What ambient temperatures are we talking about here? Are you sitting in an oven?
- Hyperthreading makes your CPU hotter.
- CPU delidding service is $50 in the United States from SiliconLottery.
- I recommend using D14 or better in terms of cooling.
- Ensure the cooling solution is mounted properly.
Here is an IPC test. (Please note that I showed PCPerspective's IPC charge in the general Skylake spoiler and they have a page about IPC gains as well.
The gains in chess were smaller than I anticipated and the gains in gaming were larger than I expected.
Oblivion and Skyrim were tested in a heavily CPU bottlenecked area. For music encoding I turned 2 flac tracks, 1 wav track, and 1 podcast in mp3 to OGG files through Foobar at 70kbps bitrate. Chess was tested with Arena 3.5 GUI and the latest Stockfish beta at the time with Sedat Canbaz's benchmarking position. Also worth noting is that overclocking the ram from DDR4 2133 to DDR4 3000 gave me a 6% FPS increase in Oblivion (CPU bottlenecked game, apparently also ram as well).
Above is a power consumption test. To state the obvious, this is a measurement of the power draw of the entire system as measured by Kill-a-Watt. ROG Realbench and Battlefield 4 use up a lot of the GPU, making the test pointless. Ram stressing is also a part of the power consumption when looking at tests like Prime or Linpack.
The PSU used was an EVGA Supernova P2 1000w. It is platinum rated, but being a 1000w rated power supply, it is not very efficient at such low loads.
Here is a small chart showing the power consumption differences between 1.4v and 1.2v on the Vcore, and idle power draw differences. Some of you may have seen a chart from Overclocking.Guide showing no power consumption differences between different power saving options. That test is relatively pointless because none of the settings changed idle voltage. Running C-states and such and setting the processor to use 1.4v on load is no difference power-draw-from-the-wall-wise compared to simply setting 1.4v manual voltage and putting that under load. While C8 state saved only 35w when compared to an idle 1.4v setting, many people do not turn off their computer or put it on standby when they are not using the computer. 35w-hour saved for 8 hours a day over a year can add up.
But don't turn on C-states out of concern for the longevity of your processor. The processor is obviously idle when C-states would kick in if it's on, so there's really not much difference.
Time-to-Crash Data:
The settings used for this test are modified ones from temperature testing. The ram was clocked back down to 2133. Linpack takes a minute to load up to maximum load, so for the results I have removed a minute from each result.
Notation is as follows:
3:00, 3/5 meaning 5 runs were done, 3 passed an hour, and 2 failed. Of the 3 that failed, the average time to crash was 3 minutes.
4.7/4.7GHz:
1.36v:
Linpack Max - 2:47, 0/5
OCCT S - 3:38, 0/6
OCCT L - 3:52, 0/3
P95 v28.7 8k - 7:00, 0/35
P95 v28.7 4069k - 1:47, 0/35
P95 v27.8 8k - 10:33, 2/5
IBT Max - 47:00, 1/2
1.3v:
x264 16T passes overnight.
1.29v:
x264 16T passes overnight 50% of the time.
4.6/4.6 GHz:
1.34v:
OCCT S - 4:34, 0/10
P95 v28.7 8k - 13:41, 2/10
Linpack Maximum - 25:04, 1/4
1.335v:
OCCT S - 2:35, 0/6
OCCT L - 3:14, 0/5
Time-to-Crash Data:
4.7/4.7GHz:
1.36v:
OCCT S - 3:38, 0/6
OCCT L - 3:52, 0/3
1.3v:
1.29v:
4.6/4.6 GHz:
1.34v:
OCCT S - 4:34, 0/10
1.335v:
OCCT S - 2:35, 0/6
OCCT L - 3:14, 0/5
Sample Size | 142 |
