Hello, i have the EVGA 1000 G2 PSU and today i received my sleeving from Nils at MDPC. So I unsleeved my 8pin CPU cable and found out that it had a capacitor on 2 cables, it was there also in the motherboard 24 pin and the VGA cables.. it was a bit sad because that ment that I could'nt sleeve it and had to buy a extension cable and try to sleeve that. Nils told me that I could just cut them off. I actually have 2 CPU cables and i'm going to cut the caps off one and test both to see if there is any problem.
My VGA is a 8pin to a 6+2pin/8pin but its really ugly:
and I was thinking how do modders avoid this crap? Do they use extension cables on the inside that connect the the supplied GPU cables(in my case the red ones) in the back?
Sorry If I sound noobish and confusing..
