SLI and Drivers Question
302 Views 9 Replies 5 Participants Last post by  PJ99
Hello everyone I have some Questions on testing my mew rig out with some games.
First off. I have 2 GTX 285's in SLI but when I do the Benchmark for GTA 4 It only averages in about 35 FPS in game and At the end it only show's One GTX 285. How is that.
Second How do I make sure that I have both card's running right and How do I see what Driverrs I have installed for the Video card?
Thanks guy's.
1 - 10 of 10 Posts
What about GTA 4? I have all the setting's on Very High or High. ANd I run the Bench and it sais that 35 is my average.
Wouldn't you think that With 2 GTX 285's it would be higher than that?
This is the driver u need to use & in the nvidia control panel it will have a setting to enable or disable your sli
http://www.nvidia.com/object/winvist...2.08_whql.html
You deff dont have sli enable'd my friend. I run it on 1 card and i get 47fps average.
The Driver Im curently useing is 182.06. Will the 08 one give me better proformance. ANd I did check I do Have SLI enabled as well as GPU physics.
yes,it will
GTA IV, for some money whoring reason, does not support SLI, right now.
Havin the latest drivers will increase performance and select sli and enable physx which will give u you better performance in games as well
THanks guy's. Im sure there will be an up-date soon. HOPE. for sli in GTA 4. But I ran the Bench with the 08 drivers and still it say 32 fps. I am running the stock clock's at 648mhz for the card. Maby overclocking it to 702 will give me better results.
1 - 10 of 10 Posts
