SLI and Linux?
327 Views 6 Replies 6 Participants Last post by  blackeagle
supported? distro?
1 - 7 of 7 Posts
I don't know that many Linux gamers >.<
I don't think it's really a gaming OS. I'm sure there's some way you can get it to work tho.
maybe by the time I actually break down and go that route it will be done?
Yes SLi is supported. Distros, tkae your pick. I know the Remix here has it done on Gentoo.
Gentoo has awesome hardware support. I bet SLI would run great on that!
Considering the worlds first desktop 64 bit OS and game was utilizing Linux and NVidia and NVidia support for Linux is so strong it should work well.
yea it should work. There are many different distros that it will work on. To game on linux you will need an emulator like http://winehq.com/ or http://www.transgaming.com/index.php...ceid=2&meid=-1
Talk to dangeroushobo or TheJester, they are both very wise with linux. Jester has gotten bf2 to work on linux too!
1 - 7 of 7 Posts
