1 - 10 of 10 Posts
Didnt wanna use the word "hack" for obvious reasons, not sure what the policy is on this forum. Anyways, I heard there was a guide on it, but I couldnt find it anywhere through search.. So anyone know where I can find a guide/files needed for this SLI hack? Also I heard 460s are an issue with it? Are they still an ISSUE and will my 890xa board work with it? I have 2 EVGA 460 badboys and wanna do this, so whats the word guys? And is there a failure rate/chance/damage?
Thanks in advance,
jaded
OG
You mean the SLI on any motherboard thing?
Edit: nevermind.
Discussion Starter #5
oh wow...890xa wasnt listed, you guys think it will still work and worth trying?
If you already have the 460s, by all means try it! Worst case scenario is you need to reinstall/repair windows.
give it a try and let us know, always nice to add to the knowledge base tht is OCN
Discussion Starter #9
experiment in progress
sorry for the ignorance, was a bit precautious about this situation, quite exciting though, I hope the scaleing/performance is up to par with traditional multi-gpu setups.
1 - 10 of 10 Posts
