1 - 4 of 4 Posts
Totally New to OCN
is that blowing air onto the cards? or away fromt he cards?
Discussion Starter #4
Yeah into the card's, the problem I was having was the sound card is in between the two gpu's and it caused them to get really hot so I modified this zalman fan bracket so it would fit a 120mm fan. It works really good even with stock cooling. The best part is it only cost $9.00.
1 - 4 of 4 Posts
