Basically was on BC2, Crashed twice with in the hour, put bios settings back to stock, rebooted in x64 sli enabled, and nv controll panel no longer shows sli
What happened to my sli
Originally Posted by Havokr505 ![]() this happened to me a while back with mm 8800GT`s.. see theres a hidden part of the Nvidia control panel that u cant access normally.... the thing u want to enable is called Coolbits... http://www.slizone.com/object/slizone_coolbits.html almost 100% sure thatll solve your problem.... |
