1 - 7 of 7 Posts
Hi Guys,
I have an issue with windows 7/crysis Very High/2x gtx275 in SLI mode 1440x900 4AA.
After about 20 minutes of playing when I try to use the sight on the guns areas of the screen go black, then whe I come out of the sight mode it goes away, but comes back when i return to sight mode.
I am using the windows 7 drivers (185.xx) not the latest Forceware drivers.
I dont think it is an over heating problem as the CPU is at 49 degrees and graphics cards are at 80-85 degrees.
has anyone had this problem before?
Super Moderator
Try using a single GPU (physically taking one out). Then try the other. See if one of your cards is faulty that way. I doubt you're seeing an improvement with SLI at that resolution anyway honestly.
I Love this Hobby!
Those are old drivers. Update your drivers.
Swap cards and ease off on OC (if OCd).
Sometimes video glitches are also due to faulty RAM. Try wapping out RAM as well.
Reactions: Mitche01
Update your drivers, thats your problem
Reactions: Mitche01
looks like it's time for some new drivers
Reactions: Mitche01
Discussion Starter #6
Hi Guys,
Thanks you for the input. I know the drivers need updating! It really is the first thing I should have done!!!
In terms of cards, i added the second card after 6 months of owning the first. I got the SLI config as i am saving up for a nice larger 24" monitor.
I will report back when I update the drivers.
Cheers,
1 - 7 of 7 Posts
