1 - 4 of 4 Posts
was wondering if you can sli different brand since i havent touched the green side since the 9800 series i'm not sure if you can
planning on sli'ing GTX465 for a customer
· Aliexpress shopper
You can SLI any card with different brands as long as they're both GTX465's.
And just as a tip, SLI GTX460's would probably be a better choice.
· Banned
Yeah, as long as they are the same amount of VRAM with the same bus speed.
the customer already has a 465 he wants a second one wasn't sure if i could do it is all
1 - 4 of 4 Posts
