1 - 5 of 5 Posts
Hope this is the right spot for this.
I've got 2 GTX 970s im throwing under water and overclocking balls to the walls.
The question is; the PCI-E power cables on my seasonic platinum 1200w PSU are single cables with 2 PCI-E power connectors at the end of each cable. Which is fine if you use use both connectors for a single card, but a hell of a mess if i need to use 2 separate cables for each gpu.
So can i get away with 1 cable with 2 connectors at the end?
Also my mobo has a spot to plug in a molex for extra power to the cards when running SLI. I'd really, really prefer not to use that (especially before i get around to sleeving the cables) can i get away without that as well?
Thank you!
Thank you!
YEP, that will work just fine.
While at the same time not using the additional molex plug my asrock z97 extreme4 has available?
Great to hear, thanks.
1 - 5 of 5 Posts
