They normally recommend you use 1 and 3 when using SLI on a 3 slot motherboard. That's what the manufacturers say anyway. However I don't believe it will make a difference. Just the temperatures will be higher on the top card.
Originally Posted by metallicamaster3 ![]() First, you need to find out the bus width in SLI. For a 780i, I think that it's x16/x8/x8, so using slot 2 or 3 wouldn't matter since they're the same width. |
Originally Posted by DuckieHo ![]() Which 780i? The 780i uses a NF200 chip... you want the two SLI cards on the PCIe expander for lower latency. |
Originally Posted by DuckieHo ![]() Use the top and bottom x16 PCIe slots then. They are PCIe 2.0 and connect to the NF200. |
