1 - 4 of 4 Posts
Can I use <span style="color:#0000FF;"><a href="http://www.newegg.com/Product/Product.asp?item=N82E16813123257" target="_blank">http://www.newegg.com/Product/Product.asp?item=N82E16813123257</a></span><br>
with out the SLi hook up..another words, I have two card that are Sli ready but don't have the attachment on the side for the SLi connecter, will they still work with this mobo?<br><br>
card:<span style="color:#0000FF;"><a href="http://www.newegg.com/Product/Product.asp?Item=N82E16814122005" target="_blank">http://www.newegg.com/Product/Product.asp?Item=N82E16814122005</a></span>
Overclockiit
That motherboard comes with the bridge you need to run sli so yes that baord will work, as for the card in the link its not an sli card so you cant use it for sli but you can use it on an sli motherboard.
Yea the card in your link isnt SLI-able, and if you are only looking to spend 140$ (70+70) then go with a single card, and a non-sli motherboard to save money, so you can get a better single card.
Like a 7950Gx2 Off of ebay brand new (im too broke to get one)<br><br>
Indeed, that 7300 card is not SLI.
1 - 4 of 4 Posts
