SLi?
628 Views 15 Replies 7 Participants Last post by  a300
I ordered thishttp://www.asrock.com/mb/overview.asp?Model=P45TurboTwins2000
motherboard. It says that there is a SLi/xFire switch card, but no reviewers that I have seen say that it is compatible with SLi.
So does it support SLi?
Also if you have one, is it good?
-Thanks.
1 - 16 of 16 Posts
no.....crossfire only....it's a P45
Originally Posted by microman
no
Verification?
So if it is xFire only, what will happen if I try to SLi?
-Thanks
-Thanks
Wont work.
Itll work for SLI not crossfire.
edit. Woops sorry about that its crossfire....didnt quite check it good.
its a intel chipset, you are incorrect.
P45TurboTwins2000
  • LGA 775 for Intel® Core™ 2 Extreme / Core™ 2 Quad / Core™ 2 Duo / Pentium® Dual Core / Celeron®, supporting Penryn Quad Core Yorkfield and Dual Core Wolfdale processors
  • All Solid Capacitor design (100% Japan-made high-quality Conductive Polymer Capacitors)
  • Intel® P45 + ICH10 Chipsets
  • Compatible with FSB 2000/1600/1333/1066/800 MHz
  • Supports Dual Channel DDR3 1333/1066 (4 x DIMM slots) with max. capacity up to 8GB and Dual Channel DDR2 1066/800/667 (2 x DIMM slots) with max. capacity up to 8GB
  • Supports ATI™ CrossFire™
  • 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
  • 6 x SATAII 3.0 Gb/s connectors, support NCQ, AHCI and Hot Plug functions
  • 2 x eSATAII 3.0 Gb/s connectors
  • PCIE Gigabit LAN 10/100/1000 Mb/s
  • 7.1 CH Windows® Vista™ Premium Level HD Audio (ALC888 Audio Codec)
  • 1 x WiFi/E header
  • Supports ASRock Instant Boot
  • Supports I. O. T. (Intelligent Overclocking Technology), ASRock OC Tuner
  • Windows® Vista™ Premium 2008 Logo Ready
  • Free Bundle: 1 x ASRock XFire Switch Card
Originally Posted by X4n4th
P45TurboTwins2000
Supports ATIâ„¢ CrossFireâ„¢
1 x WiFi/E header
On the icon below the picture of the motherboard it says SLi/XFire switch card.
:swearing:Tricked me into buying it
maybe we'll see how good newegg's service is if one 9600 isn't enough.
Also, should I
1. keep my ECS and get a GTS250/Radeon 4850/4770
2. Get a 650i SLi ECS Open Box
3. do nothing
What is a SLI/xFire switch card anyways?
To The OP, it will only support Crossfire.
Also I would buy an HD4830 or something. It will outperform the 9600 gt.
O wow sorry i was wrong. It supports Crossfire as is but you can buy a switch card that makes it support SLI. Thats cool. It looks like the switch card holds the cfx/sli chipsets
Originally Posted by ipod4ever
Try this maybe something about switch cards.
http://www.overclock.net/amd-motherb...itch-card.html
Awww...
Has anyone tried it?
Anyhow +REP to everyone!
1 - 16 of 16 Posts
