1 - 17 of 17 Posts
Could be your HD, but more likely all the programs and services you have starting up.
Go to Start Menu, then click Run. Type Msconfig, and go to the startup tab. Unclick anything you dont need running when windows first starts. you can also go to run, and type services.msc for a list of services you can stop. But I wouldn't mess with anything in there unless you know what you are doing.
the only thing that is slowing me down is the booting line( i dont noe how to explain it, but like there a load bar at the bottom of the monitor), that takes forever to load. Any way to set it?
nornton firewall slows everything down
most servicies are that important, theres a faq about which ones are necesarry roung here somewhere
and also you can turn off all the serial ports and what not you arent using in the bios
also
tell XP how big your cache is
in your registry,
search for secondleveldatacahce
something like that
I know what you mean, I would try what I previously recommended. You could also Defragment your harddrive to see if that helps. Actually you should defrag it once a month anyways. To defrag, double click "my computer", then right click your Hard drive, select properties. Then click the tools tab.
Then you can defragment.
Discussion Starter #7
does this mean , the larger the cache the slower it boot.. cause am comparing my 1mbL2 cache with my other computer which is a 512kbL2 cache and the 512kb seem to be alot faster at booting.
where are you chengin the cache
but whatever is faster, Id go with that
like I told mine I had a 1024 cache when I had a 256
and It was lots faster and worked fine
weird tho
p4 423 so I dont know if this applies anymor
Old school
Originally Posted by thehybridpyro
also
in your registry,
something like that
In the registry is says SecondLevelDataCache 3 times. Modify or modify binary?
Anyway I'll try filling in 512 now. I'll change all 3.
Edit: Decimal or Hexadecimal?
decimal and type in how big in kb your cahce is
is in current controll set/sessionmanager
only the current control set one
it changes all of em
its kb dude
a 256mb cache is like haveing 128 gigs of ram
but yes you type in how big it is
my computer used to take forever to get from the windows loading bar screen to the login screen and after a lot of investigating leading to a reformat, i found out it was my sound card driver that was causing the problem. appearantly it isnt compatable with my version of windows or something so i just uninstalled the driver and took out the card and am using onboard sound now. I have the Turtle Beach Riveara sound card, might wanna check out some of your drivers and see if there are any compatability issues there.
1 - 17 of 17 Posts
