1 - 13 of 13 Posts
I have a Sony CRX-320E CD-R/RW drive, it says it will write at 52x, so does Optical Info, but whenever I try the most Nero (...or any other program) will do is 40x – I burn a lot of CD’s and wondered if this could be fixed, and a search of the internet showed that to enable the “52x†mode I have to hold the eject button in for X seconds, this used to work, but now I can’t remember how long I have to do it for, so I decided to see if I could find a firmware update for it – But where do I find a firmware update for it? How do I install it?
Check with the maker of the device for a "firmware" update.
<div>Originally Posted by <strong>The Duke</strong></div>
<div style="font-style:italic;">Check with the maker of the device for a "firmware" update.</div>
</td>
</tr></table></div>
i have - no luck, but ive seen firmware updates mentioned for my drives
Several of the posts I found on that drive were compalints, including a firmware update just caused more problems.<br>
I guess you either live with it or buy a new device.
Discussion Starter #6
<div>Originally Posted by <strong>cokker</strong></div>
<div style="font-style:italic;">Are the CD's rated at 52x?</div>
</td>
</tr></table></div>
yes, thats what i thought at first!<br><br>
Well it looks like i either by a DVD writer or a new fan...
<div>Originally Posted by <strong>Jakg</strong></div>
<div style="font-style:italic;">yes, thats what i thought at first!<br><br>
Well it looks like i either by a DVD writer or a new fan...</div>
</td>
</tr></table></div>
<br>
I recommend an LG dual layer drive....they burn CDs FAST, and it's the best burn I've ever got. The only coasters I've made have been my fault, cause I didn't use the right software to convert the dvd..and it just grabled it lol. The burner is AWESOME!
Discussion Starter #9
<div>Originally Posted by <strong>Sideburns</strong></div>
<div style="font-style:italic;">if the media is rated for 52x....then it seems like your drive is just a little messed up.</div>
</td>
</tr></table></div>
oh fun - well seeing as i have an exteral writer if i need it, i might just save for new tech
<div style="font-style:italic;">I recommend an LG dual layer drive....they burn CDs FAST, and it's the best burn I've ever got. The only coasters I've made have been my fault, cause I didn't use the right software to convert the dvd..and it just grabled it lol. The burner is AWESOME!</div>
</td>
</tr></table></div>
Agreed.<br><br>
LG or Samsung (i have a Samsung in the wifes rig, very good<img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">)
Discussion Starter #11
CD Burner (Well, DVD burner) or sound card (as a pose to AC97!) :S<br><br>
I have a set of Creative P380 speakers - would a soundcard make a sound quality difference with them?
I have similar speakers to you (same sub box anyhoo), a good sound card eg: Audigy 2 ZS or better will free up a little CPU power and make the music etc sound a little clearer.<br><br>
I don't mind my AC97 at the moment, set it up just right and it's grand<img alt="" class="inlineimg" src="/images/smilies/biggrin.gif" style="border:0px solid;" title="Big Grin">
Discussion Starter #13
<img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" /> looks like i have another thing to add to the "want" list!
1 - 13 of 13 Posts
