1 - 14 of 14 Posts
1 week ago, when i first overclocked this opty (check spex below ). With those settings
Vcore 1.55 ( this is my max )
FSB 268mhz
Multi x11
Vdimme 2.85v ( I got an hynix model for OCZ ram which has 2-3-2-5 timings as defualt not 2-2-2-5 as the real OCZ ram )
DIVIDER or mem max clock 333mhz
HTT x3
Timings 2.5-3-3-7
then i benched and i scored around 26004 in 3DMARK01
Now after 1 week i benched again for same settings ( xcept i have tried some methods for hitting 3ghz that failed) Then i reset the settings to the old settings which i said above .......
THOSE
FSB 268mhz
Multi x11
HTT x3
Timings 2.5-3-3-7
I benched then i scored and it was like 100 point less it was 25041 :S . I know u will say maybe u changed somethin in BIOS by mistake i Actully didnt , cuz i reset the cmos from the battery
and same exact results any help
THanks.
it's probably your memory, is your system prime stable? You are probably overlooking a small change.
Run the test again...that's not that much of a difference in score...you sure you correctly recorded the first score?
yes they r in the website iam sure of the records and yes i have posted a pic of it. I was stable for 4 houres
100 is big difference
Discussion Starter · #12 ·
Originally Posted by what?
Defrag your hardrive?
Test right after you boot, well right after you shut down excess programs in teh background. Reboot after every run.
Defragment has been done many times after every unistall or install , viruses=clean, adwares=clean, spywares=clean,registery=allfixed.. iam using a none free programs for tunning up the pc. U can see them in my pic i attached.
that time does seem a little slow, but that could be due to your memory running at that speed. It's most likely accurate and you just got a very good run that one time, stuff like that happens.
Get that memory switched out soon, that stuff sucks...
Discussion Starter · #14 ·
true, i woke up really late today didnt have time to contact the seller since he closes early bah.
1 - 14 of 14 Posts
