My pc becomes REALLY slow after I start running eMule... it seems to eat up my memory (I got 2x256mb) and it gets really really slow, I can't do anything else when it's on. I don't think that's normal, what can I do to fix it or try to fix it?
yeah def. use full system scan. it searches all of you computer, not just the selected parts. also, use spybot search & destroy. it picks up where adaware doesent...i use both...heres a link: http://www.download.com/Spybot-Searc...ubj=dl&tag=but
i use both in combination, they both work great together.
EDIT: when you hit start, it shows up with some scan options. select full system scan.
If you configure it right, 'Smart Scan' is better than full system scanning. Problem is, I can't remember how to do it...
Adware and others are also sometimes is like weed killer - they kill whats above ground, but not the root. Hijack this is better than all the other anti-spyware programs out there, you just got to be careful you don't delete the wrong thing :swearing:
1 - 19 of 19 Posts
