1 - 2 of 2 Posts
Hello,
My name is frank, and I have recently had trouble with my wireless D-link WBR-1310 Router. Two days ago everything was working fine, my wireless connection from the router to my macbook was fine and the wired connection to my desktop pc was also fine. I went to bed and when I woke up the next day everything was still ok. About 3 hours after I had first turned on the PC that next day my wired connection started spiking and dropping connection frequently, maybe every 5-10 minutes or so. I play world of warcraft and I also use Mumble VoiP Program and my pings in both are over 800 constantly now making it impossible to stay connected to either program. Sometimes it will drop down to regular numbers (25-50ms, I play on eastern servers as I am in NY) but then rapidly jumps back up into the 1,000's. My wireless connection is still fine though nothing has happened to that, only my wired connection is messing up.
I've tried changing my speed and duplex settings on my onboard NVIDIA nForce 10/100 Mbps Ethernet which is what im using but it hasn't helped. Hopefully you guys can help me out =[.
Wireless Router: D-link WBR-1310
Hardware Version: B1
Firmware Version: 2.02
Here is the Ipconfig /all:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Freemasonry>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Freemasonry-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce 10/100 Mbps Ethernet
Physical Address. . . . . . . . . : 00-21-97-68-B2-A2
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::797b:bfc:906a:f12%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Tuesday, September 18, 2012 1:29:02 PM
Lease Expires . . . . . . . . . . : Tuesday, September 18, 2012 4:33:31 PM
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 234889623
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-17-B5-CE-88-00-21-97-68-B2-A2
DNS Servers . . . . . . . . . . . : 192.168.0.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter isatap.{ED6E78B3-8678-46B9-9118-3DA0EBF0CF17}:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:3c19:1b4f:e76d:7700(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::3c19:1b4f:e76d:7700%12(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Now is there anybody else on the network?
It looks like the Router is not able to support the load that your PC is having.
Also try posting a speedtest @ speedtest.net, and also pingtest as it might help us.
1 - 2 of 2 Posts
